[postgis-users] spatial joins (geometry collection?)
Tyler Mitchell TMitchell at lignum.com
Mon Apr 19 09:27:51 PDT 2004
Brent, did you get anywhere on your question or is it still open?
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 04/15/2004 10:40:00
AM:
> I plan to join a table of line features with a table of polygons, based
on
> which lines cross which polygons. This is for a spatial analysis of the
line
> data by dividing the survey area into small cells to give a raster style
> breakdown of the line attributes.
> The data will then be queried with a variety of "select
> <sum/avg/etc> ... group
> by cell;" sql to give a wide range of models over the area which can be
> displayed as coloured cells or contoured.
> The result, if inserted into a new table, will need to convert the
> two distinct
> geometries into a single geometry collection matching the two geometries
(as I
> believe you can't have two geometry columns in a table).
> I'll need to pre-define the the new table & add the geometry to it, but
how do
> I write the joining sql to merge the two separate geometries into the
new
> table?
>  Thanks again...
>    Brent Wood
> postgis-users mailing list
