[postgis-users] spatial joins (geometry collection?)
Wood Brent pcreso at pcreso.com
Mon Apr 19 12:55:50 PDT 2004
--- Tyler Mitchell <TMitchell at lignum.com> wrote:
> Brent, did you get anywhere on your question or is it still open?
Still open :-) Any suggestions welcome!
Brent
> Tyler
> > I plan to join a table of line features with a table of polygons, based
> on
> > which lines cross which polygons. This is for a spatial analysis of the
> line
> > data by dividing the survey area into small cells to give a raster style
> > breakdown of the line attributes.
> > The data will then be queried with a variety of "select
> > <sum/avg/etc> ... group
> > by cell;" sql to give a wide range of models over the area which can be
> > displayed as coloured cells or contoured.
> > The result, if inserted into a new table, will need to convert the
> > two distinct
> > geometries into a single geometry collection matching the two geometries
> (as I
> > believe you can't have two geometry columns in a table).
> > I'll need to pre-define the the new table & add the geometry to it, but
> how do
> > I write the joining sql to merge the two separate geometries into the
> new
> > table?
> >  Thanks again...
> >    Brent Wood
