[postgis-users] help creating srid for custom projection
Paul Ramsey pramsey at refractions.net
Mon Apr 19 15:34:48 PDT 2004
Mostly you need a valid proj4 definition. You can fill in the rest of
the values almost anyway you want (as long as srid remains unique).
INSERT INTO spatial_ref_sys (srid, auth_name, auth_srid, proj4text)
VALUES (500000,'BWOOD',500000,'+proj=merc +lat_ts=-41 +lon_0=100
+k=1.000000 +x_0=0 +y_0=0 +ellps=WGS84 +units=m');
Paul
Wood Brent wrote:
> Hi,
> I have data in a custom projection written into a postgis table from a
> shapefile.
> I have a copy of some docs describibing srid's but am still not sure how to
> create an appropriate entry in tne spatial_ref_sys table that will allow me to
> reproject (transform) the data to lat/long to allow spatial queries/joins with
> my other lat/long datasets.
> I have been told the supplied data coordinates are mercator northings &
> eastings in metres, using wgs84 spheroid, with a central meridian of 100E and
> latitude of true scale at 41S. There are no false northing/easting offsets.
> Can someone suggest how this can be specified in the spatial_ref_sys table?
> Thanks
>   Brent Wood
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
