[postgis-users] Mapserver PostGIS Layer returns nothing
Paul Ramsey
pramsey at refractions.net
Wed Apr 28 16:16:53 PDT 2004
Check the mapserver log for the SQL being generated by the postgis layer
and pump that into psql. The only reason to get a blank map, generally,
is if your layer is actually not on, there is no data, or your extents
are outside the area of data. Take the mapfile you know works with your
demo shape file, and, changing nothing but the connectiontype and
connection information, try again.
Wesley Dyk wrote:
> Summary: Trying to use a PostGIS layer of POINT geometries within the
> extent "-108.375280 40.032 -107.95597 40.24679" (from ogrinfo of the
> dumped shapefile), but get no results.
> PostgreSQL 7.4.2
> PostGIS 0.8.1
> mapserver 4.0.2
> I have been working with mapserver for a few weeks now and I have been
> able to create simple mapfiles with several layers. They all seem to
> work great, except for PostGIS. I have messed around with the LAYER
> definition and I know what changes will generate errors and which ones
> will just return whitespace (which are the only two results that I can
> get). I dumped my table to a shapefile. Creating a layer based on that
> shapefile works just as the PostGIS layer is supposed to. I tried
> reloading the shapefile into a new table, once with SRID=-1 and once
> with SRID=4269. I can't get anything but whitespace from the database.
> I have tried to make the extent to encompass any possible point, with
> and without projection, but nothing.
> What could I do to figure out what is going wrong?
> This is the latest mapfile I have tried (with nothing but the PostGIS
> layer in question).
> -----------------------postgis.map--------------------------------
> SYMBOL
> NAME "triangle"
> TYPE vector
> POINTS
> 0 4
> 2 0
> 4 4
> 0 4
> END
> END
> SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> MAP
> NAME TIMS
> IMAGETYPE PNG
> EXTENT -108.375280 40.032 -107.95597 40.24679
> #EXTENT -111.8 39.0032 -103.002 46.3
> SIZE 640 480
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> FONTSET "fonts/fonts.list"
> WEB
> IMAGEPATH "/u01/mapserver/tims/tmp/"
> IMAGEURL "/tims/tmp/"
> LOG "/u01/mapserver/tims/tims1.log"
> END
> PROJECTION
> "init=EPSG:4269"
> END
> #PostGIS Well Header
> LAYER
> NAME wellheader
> STATUS DEFAULT
> DEBUG ON
> CONNECTIONTYPE postgis
> CONNECTION "user=aus dbname=TIMS host=denlx02"
> DATA "the_geom from wellheader"
> TYPE POINT
> PROJECTION
> "init=EPSG:4269"
> END
> #When the display works use different classes for certain conditions
> CLASS
> SYMBOL 'triangle'
> OUTLINECOLOR 0 255 0
> SIZE 5
> END
> END
> END
> postgis-users mailing list
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
