[postgis-users] Mapserver PostGIS Layer returns nothing
Changqing Zhou
czhou at cs.umn.edu
Thu Apr 29 08:01:49 PDT 2004
How do you configure mapserver to print our PSQL? Where is your log file?
I had log file defined in the web tag in the mapfile and it does not give
me the psql.
Thanks,
Changqing
On Wed, 28 Apr 2004, Paul Ramsey wrote:
> Check the mapserver log for the SQL being generated by the postgis layer
> and pump that into psql. The only reason to get a blank map, generally,
> is if your layer is actually not on, there is no data, or your extents
> are outside the area of data. Take the mapfile you know works with your
> demo shape file, and, changing nothing but the connectiontype and
> connection information, try again.
> Wesley Dyk wrote:
> > Summary: Trying to use a PostGIS layer of POINT geometries within the
> > extent "-108.375280 40.032 -107.95597 40.24679" (from ogrinfo of the
> > dumped shapefile), but get no results.
> > PostgreSQL 7.4.2
> > PostGIS 0.8.1
> > mapserver 4.0.2
> > I have been working with mapserver for a few weeks now and I have been
> > able to create simple mapfiles with several layers. They all seem to
> > work great, except for PostGIS. I have messed around with the LAYER
> > definition and I know what changes will generate errors and which ones
> > will just return whitespace (which are the only two results that I can
> > get). I dumped my table to a shapefile. Creating a layer based on that
> > shapefile works just as the PostGIS layer is supposed to. I tried
> > reloading the shapefile into a new table, once with SRID=-1 and once
> > with SRID=4269. I can't get anything but whitespace from the database.
> > I have tried to make the extent to encompass any possible point, with
> > and without projection, but nothing.
> > What could I do to figure out what is going wrong?
> > This is the latest mapfile I have tried (with nothing but the PostGIS
> > layer in question).
> > -----------------------postgis.map--------------------------------
> > SYMBOL
> > NAME "triangle"
> > TYPE vector
> > POINTS
> > 0 4
> > 2 0
> > 4 4
> > 0 4
> > END
> > END
> > SYMBOL
> > NAME "circle"
> > TYPE ellipse
> > FILLED TRUE
> > POINTS
> > 1 1
> > END
> > END
> > MAP
> > NAME TIMS
> > IMAGETYPE PNG
> > EXTENT -108.375280 40.032 -107.95597 40.24679
> > #EXTENT -111.8 39.0032 -103.002 46.3
> > SIZE 640 480
> > SHAPEPATH "data"
> > IMAGECOLOR 255 255 255
> > FONTSET "fonts/fonts.list"
> > WEB
> > IMAGEPATH "/u01/mapserver/tims/tmp/"
> > IMAGEURL "/tims/tmp/"
> > LOG "/u01/mapserver/tims/tims1.log"
> > END
> > PROJECTION
> > "init=EPSG:4269"
> > END
> > #PostGIS Well Header
> > LAYER
> > NAME wellheader
> > STATUS DEFAULT
> > DEBUG ON
> > CONNECTIONTYPE postgis
> > CONNECTION "user=aus dbname=TIMS host=denlx02"
> > DATA "the_geom from wellheader"
> > TYPE POINT
> > PROJECTION
> > "init=EPSG:4269"
> > END
> > #When the display works use different classes for certain conditions
> > CLASS
> > SYMBOL 'triangle'
> > OUTLINECOLOR 0 255 0
> > SIZE 5
> > END
> > END
> > END
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
