[postgis-users] Problems with Select by Polygon - pgsql75win
David Blasby
dblasby at gmail.com
Tue Aug 3 11:09:43 PDT 2004
What version of mapserver and postgresql are you using?
On Tue, 3 Aug 2004 13:59:45 -0400, Randy Page <randy.page at terraverge.com> wrote:
> Zamil,
> Great idea! It worked like a charm, and gave me the following (corrected)
> SQL:
> SELECT asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
> tracts_c WHERE the_geom && setSRID('BOX3D(-78.83 35.87,-78.7 35.96)'::BOX3D,
> find_srid('','tracts_c','the_geom') )
> This sql executes in less than a second and returns the expected results.
> So, why is mapserver hanging on this?
> Thanks,
> Randy
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Zamil
> Murji
> Sent: Tuesday, August 03, 2004 1:50 PM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Problems with Select by Polygon - pgsql75win
> Why don't you try purposely making a mistake in your data statement. I like
> to spell my table name wrong. Mapserv will die with an error message that
> gives you the sql statement it was trying to execute. Change all the
> mistakes
> back to the proper table name and run that select statement in postgres.
> Do a query analyze on that...
> Hope that helps.
> Zamil
> [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Randy
> Page
> Sent: Tuesday, August 03, 2004 11:45 AM
> To: 'PostGIS Users Discussion'
> pgsql75win
> David,
> I can't seem to get to that point due to the timeout. I even bumped the
> timeout up to 20,000 seconds with no change. I have been watching the disk
> & cpu usage on the PostGIS server, and it's doing absolutely nothing during
> the time the request is taking place.
> Randy
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of David
> Blasby
> Sent: Tuesday, August 03, 2004 1:03 PM
> Subject: Re: [postgis-users] Problems with Select by Polygon - pgsql75win
> it should be writing it back to your web browser. Do a "view page
> source...".
> dave
> On Tue, 3 Aug 2004 11:57:55 -0400, Randy Page <randy.page at terraverge.com>
> wrote:
> > Dave,
> > Thanks for the advice. I tried this, but I am not sure where MS is
> writing
> > the debug info (I am using IIS.) I looked in the IIS logs, but didn't
> see
> > anything but the basic request.
> postgis-users mailing list
