[postgis-users] again try to draw points
PINKTOMATE pinktomate at spymac.com
Fri Aug 6 14:09:42 PDT 2004
No, I need to do it in postgis or postgresql not in arcview
thanks for your time, excuse me, but the question is simple
> > If I have a table in excel with name of point  and coordinates x,y, I
> > can convert it in .dbf right??, this is the format of data table in
> > shapefile arcview, Only I need is to represent this points in a
> > shapefile as the same form of command "add event theme" in arcview.
> > , is possible by postgis, by shapetools, by what tool????
> > that the question
> > Regards write soon your answer
El vie, 06-08-2004 a las 15:41, Randy James escribió:
> Hi
> If you have it open in arcview just go to [theme] and [convert to shapefile]
> > that the question
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Do you Yahoo!?
> Read only the mail you want - Yahoo! Mail SpamGuard.
> http://promotions.yahoo.com/new_mail
