[postgis-users] again try to draw points
Dylan Keon
keon at nacse.org
Fri Aug 6 15:00:21 PDT 2004
As others have stated, it's probably best to first create a shapefile
using the shapelib tools. Or if you have MapServer installed and
configured with Perl/PHP/Python and dbf tools (e.g., configure PHP with
DBF support), you can use MapScript to do the same thing.
One way to do it:
1) export your Excel table as a delimited text file
2) use shapelib (or MapScript) to parse the file and create a shapefile
3) import shapefile into PostgreSQL/PostGIS using shp2pgsql
--Dylan
On 08/06/2004 02:09 PM, PINKTOMATE wrote:
> No, I need to do it in postgis or postgresql not in arcview
> thanks for your time, excuse me, but the question is simple
>>>If I have a table in excel with name of point and coordinates x,y, I
>>>can convert it in .dbf right??, this is the format of data table in
>>>shapefile arcview, Only I need is to represent this points in a
>>>shapefile as the same form of command "add event theme" in arcview.
>>>, is possible by postgis, by shapetools, by what tool????
>>>that the question
>>>Regards write soon your answer
> El vie, 06-08-2004 a las 15:41, Randy James escribió:
>>Hi
>>If you have it open in arcview just go to [theme] and [convert to shapefile]
>>>that the question
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>Do you Yahoo!?
>>Read only the mail you want - Yahoo! Mail SpamGuard.
>>http://promotions.yahoo.com/new_mail
