[postgis-users] again try to draw points
Jaime Mejía
jaime at maintask.com
Sat Aug 7 10:31:32 PDT 2004
sorry, i poor english.
Your problem is same....
Re: [postgis-users] Help with wkt and pgsql2shp
Basically, if I understand your question you need to:
1. create a table in postgresql to house your data (any table will do)
2. use the command addGeometryColumn() to the table that you just
created: (http://postgis.refractions.net/docs/x321.html#AEN391)
3. Use the command GeometryFromText(varchar, integer) to insert your WKT
data into the table: ( http://postgis.refractions.net/docs/c673.html )
4. Export the resulting data using pgsql2shp
At 10:40 AM 8/6/2004 +0200, you wrote:
> I have a string containng the WKT representation of an area. I need to
> convert it into a shape file. I wanted to use pgsql2shp because i also
> need
> to store this string. The problem is I need to know how to build a
> table in
> order to be able to run pgsql2shp on it.
> Could someone explain me the structure of a table as expected by
> pgsql2shp
> or at least point me to some documentation about it?
> Thx a lot and excuse me if my question is trivial.
> Ing. Simone Giannecchini
> NATO Undersea Research Centre
> Viale S. Bartolomeo 400
> 19138 La Spezia, Italy
> Tel: 390187527441
> Cell: 3480064736
PINKTOMATE wrote:
>No, I need to do it in postgis or postgresql not in arcview
>thanks for your time, excuse me, but the question is simple
>>>If I have a table in excel with name of point and coordinates x,y, I
>>>can convert it in .dbf right??, this is the format of data table in
>>>shapefile arcview, Only I need is to represent this points in a
>>>shapefile as the same form of command "add event theme" in arcview.
>>>, is possible by postgis, by shapetools, by what tool????
>>>that the question
>>>Regards write soon your answer
>El vie, 06-08-2004 a las 15:41, Randy James escribió:
>>Hi
>>If you have it open in arcview just go to [theme] and [convert to shapefile]
>>>that the question
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at postgis.refractions.net
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>Do you Yahoo!?
>>Read only the mail you want - Yahoo! Mail SpamGuard.
>>http://promotions.yahoo.com/new_mail
