[postgis-users] installation problems: can't find makefile.global, makefile.shplib
Michael Mallete
mrmallete at yahoo.com
Sun Aug 8 19:34:08 PDT 2004
first i installed postgresql 7.4.3 from source. just
the basic ./configure, gmake, then gmake install. so
it was all installed in /usr/local/pgsql. then i
created postgres.sh inside /etc/profile.d/.
when i was about to untar the postgis package, i just
found out that there is no contrib folder in my
postgres source tree. so i just created one i.e.
/usr/local/pgsql/contrib. and extracted the postgis
package there. when i then run make, this happens:
Makefile:38: ../../src/Makefile.global: No such file
or directory
Makefile:160: /src/Makefile.shlib: No such file or
directory
make: *** No rule to make target
`/src/Makefile.shlib'. Stop.
so where did i go wrong?
thanx!
-Myk
>> hello everone! just starting out here. i hope you
>> wouldn't mind me posting these questions here which
>> could've been posted in the past.
>> first off, when i was to untar the postgis tarball,
i
>> didn't see any contrib folder in my postgres source
>> tree. so instead i created one as root.
>> then when i executed "make" or "gmake," this
happens:
file
>> or directory
>> directory
>> was there anything wrong with my postgres
>> installation? or should i have edited something in
>the
>> makefile? my postgres source tree is
>/usr/local/pgsql/
>> help! thanx in advance :)
>Where did you extract the postgis package ?
>By default it wants to in in the pgsql contrib/
>directory,
>but you can specify pgsql source with the environment
>variable
>PGSQL_SRC if you need.
>--strk;
>> -Myk
__________________________________
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
http://promotions.yahoo.com/new_mail
