[postgis-users] installation problems: can't find makefile.global,makefile.shplib
dhouston at beyondcompliance.ca
Sun Aug 8 20:36:29 PDT 2004
Hello Michael,
Which directory did you issue ./configure, gmake, gmake install? This will be
your PostgreSQL source. By default, PostgreSQL installs in /usr/local/pgsql.
This is not the source. Wherever you issued ./configure, gmake and gmake
install will have a contrib directory where you install PostGIS from. Don't
worry, PostGIS will know PostgreSQL resides at /usr/local/pgsql and install to
there.
Hope this helps,
Darren H.
Michael Mallete (mrmallete at yahoo.com) wrote:
> first i installed postgresql 7.4.3 from source. just
> the basic ./configure, gmake, then gmake install. so
> it was all installed in /usr/local/pgsql. then i
> created postgres.sh inside /etc/profile.d/.
> when i was about to untar the postgis package, i just
> found out that there is no contrib folder in my
> postgres source tree. so i just created one i.e.
> /usr/local/pgsql/contrib. and extracted the postgis
> package there. when i then run make, this happens:
> Makefile:38: ../../src/Makefile.global: No such file
> or directory
> Makefile:160: /src/Makefile.shlib: No such file or
> directory
> make: *** No rule to make target
> `/src/Makefile.shlib'. Stop.
> so where did i go wrong?
> thanx!
> -Myk
> >> hello everone! just starting out here. i hope you
> >> wouldn't mind me posting these questions here which
> >> could've been posted in the past.
> >> first off, when i was to untar the postgis tarball,
> i
> >> didn't see any contrib folder in my postgres source
> >> tree. so instead i created one as root.
> >> then when i executed "make" or "gmake," this
> happens:
> file
> >> or directory
> >> directory
> >> was there anything wrong with my postgres
> >> installation? or should i have edited something in
> >the
> >> makefile? my postgres source tree is
> >/usr/local/pgsql/
> >> help! thanx in advance :)
> >Where did you extract the postgis package ?
> >By default it wants to in in the pgsql contrib/
> >directory,
> >but you can specify pgsql source with the environment
> >variable
> >PGSQL_SRC if you need.
> >--strk;
> >> -Myk
> __________________________________
> Do you Yahoo!?
> Yahoo! Mail - 50x more storage than other providers!
> http://promotions.yahoo.com/new_mail
> postgis-users mailing list
