[postgis-users] installation problems:can't find makefile.global, makefile.shplib
Michael Mallete
mrmallete at yahoo.com
Sun Aug 8 21:31:25 PDT 2004
hello mr. darren! i've already installed postgresql
7.4.3 and it's up and running. the source tree is
located at the default /usr/local/pgsql directory.
my problem is, when i run make for postgis, it looks
for makefile.global and makefile.shlib which appears
to be missing. my postgres source tree doesn't have a
contrib folder so i just manually added one.
so am i missing something? some package perhaps?
thanx!
-Myk
>Hello Michael,
>Which directory did you issue ./configure, gmake,
gmake install? This will be
>your PostgreSQL source. By default, PostgreSQL
installs in /usr/local/pgsql.
>This is not the source. Wherever you issued
./configure, gmake and gmake
>install will have a contrib directory where you
install PostGIS from. Don't
>worry, PostGIS will know PostgreSQL resides at
/usr/local/pgsql and install to
>there.
>Hope this helps,
>Darren H.
>Michael Mallete (mrmallete at yahoo.com) wrote:
>> first i installed postgresql 7.4.3 from source.
just
>> the basic ./configure, gmake, then gmake install.
so
>> it was all installed in /usr/local/pgsql. then i
>> created postgres.sh inside /etc/profile.d/.
>> when i was about to untar the postgis package, i
just
>> found out that there is no contrib folder in my
>> postgres source tree. so i just created one i.e.
>> /usr/local/pgsql/contrib. and extracted the postgis
>> package there. when i then run make, this happens:
>> Makefile:38: ../../src/Makefile.global: No such
file
>> or directory
>> Makefile:160: /src/Makefile.shlib: No such file or
>> directory
>> make: *** No rule to make target
>> `/src/Makefile.shlib'. Stop.
>> so where did i go wrong?
>> thanx!
>> -Myk
>> >> hello everone! just starting out here. i hope
you
>> >> wouldn't mind me posting these questions here
which
>> >> could've been posted in the past.
>> >> first off, when i was to untar the postgis
tarball,
>> i
>> >> didn't see any contrib folder in my postgres
source
>> >> tree. so instead i created one as root.
>> >> then when i executed "make" or "gmake," this
>> happens:
>> file
>> >> or directory
or
>> >> directory
>> >> was there anything wrong with my postgres
>> >> installation? or should i have edited something
in
>> >the
>> >> makefile? my postgres source tree is
>> >/usr/local/pgsql/
>> >> help! thanx in advance :)
>> >Where did you extract the postgis package ?
>> >By default it wants to in in the pgsql contrib/
>> >directory,
>> >but you can specify pgsql source with the
environment
>> >variable
>> >PGSQL_SRC if you need.
>> >--strk;
>> >> -Myk
__________________________________
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
