[postgis-users] long list of error and warning messages	atinstallation
    Michael Mallete
    mrmallete at yahoo.com
    Mon Aug  9 18:42:10 PDT 2004
hello mr. Cave-Ayland! i see. so that means i have to
download geos too because i am installing it with geos
support. i though both libraries already came with the
package. silly me. also, i am assuming i should
install from source also and not the rpm packages for
fc2 because rpm's install packages differently. i hope
i got that right.
thank you so very much. you have been very helpful. :)
-Myk
>Hi Michael,
>It looks as though you're compiling PostGIS with
>reprojection support
>without having installed the PROJ.4 library first. If
>you need
>reprojection support, then you can download and
install >PROJ.4 from
>www.remotesensing.org/proj. Otherwise open the file
>"Makefile" in the
>postgis-0.8.2 directory and change the line
USE_PROJ=1 >to USE_PROJ=0
>which will disable reprojection support in your
build. >Once this is
>complete, run "make" again and you should find that
the >build will
>complete.
>Kind regards,
>Mark.
__________________________________
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
