[postgis-users] other errors during postgis.sql command
Benedetto Porfidia
benedetto.porfidia at fastwebnet.it
Tue Aug 10 11:55:50 PDT 2004
Mark Cave-Ayland wrote:
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On
>>Behalf Of Benedetto Porfidia
>>Sent: 10 August 2004 17:40
>>To: PostGIS Users Discussion
>>Subject: [postgis-users] other errors during postgis.sql command
>>Hallo All
>>I have installed postgis on latest postgres sources with no
>>errors and all seem to be gone ok. but when I try the psql
>>command i have these similar errors to the
>>previous message.
>>I tried to drop the db, run ldconfig with the path found with "find
>>/-name libpostgis.so.0.8", create a new db,
>>run createlang.... ,but i have the same error.
>>postgres at bumbum:/home/jodalap$ /usr/local/pgsql/bin/psql -d gis_db -f
>>/usr/pg_data/postgis.sql
>>BEGIN
>> message
>> PL/PgSQL is installed.
>>(1 row)
>>psql:/usr/pg_data/postgis.sql:47: NOTICE: type "histogram2d"
>>is not yet
>>definedDETAIL: Creating a shell type definition.
>>psql:/usr/pg_data/postgis.sql:47: ERROR: could not load library
>>"/usr/local/pgsql/lib/libpostgis.so.0.8":
>>/usr/local/pgsql/lib/libpostgis.so.0.8: undefined symbol:
>>pj_get_release
>>psql:/usr/pg_data/postgis.sql:52: ERROR: current transaction is
>>aborted, commands ignored until end of transaction block
>>.etc etc (the same for all lines) and
>>commit
>>please, someone can give some help
>>thanks
>Hi Benedetto,
>Looking at the current CVS of PostGIS shows that postgis_transform.c
>recently has been changed to use the function pj_get_release() that was
>only introduced with version 4.4.8 of PROJ.4. Therefore if you upgrade
>to PROJ.4.4.8, then you should find that you can build and use the
>current CVS version of PostGIS successfully.
>strk, can we detect the version of PROJ.4 by checking PJ_VERSION in
>/include/proj_api.h and only include the call to pj_get_release() if we
>are >= 448?
>Kind regards,
>Mark.
>Mark Cave-Ayland
>Webbased Ltd.
>Tamar Science Park
>Derriford
>Plymouth
>PL6 8BX
>England
>Tel: +44 (0)1752 764445
>Fax: +44 (0)1752 764446
>This email and any attachments are confidential to the intended
>recipient and may also be privileged. If you are not the intended
>recipient please delete it from your system and notify the sender. You
>should not copy it or use it for any purpose nor disclose or distribute
>its contents to any other person.
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
Many thanx
upgraded to proj448 and all is ok
b.p.
