[postgis-users] GEOS breaks following multi(geomunion())
Michael Choy
mkchoy at stanford.edu
Tue Aug 10 12:31:35 PDT 2004
Setup:
Power Mac G5 dual 2.0 GHz
Mac OS X Server 10.3.5
Postgresql 7.4.3
Postgis 0.8.2
GEOS 1.0.0
All compiled with GCC 3.4.1
I have a script that repeated calls multi(geomunion()) that essentially
aggregates adjacent polygons. It runs fine on a Linux box with
Postgresql 7.4, Postgis 0.8.2 and GEOS 1.0.0, and I am now trying to
migrate to a Mac. On the Mac, it runs briefly, aggregating about 3
pairs, then hangs. Running ps reveals:
14973 std R 15:33.08 postgres: mkchoy bayarea ::1 SELECT
But nothing is happening. I checked my GEOS install with the following:
bayarea=# select intersection('POINT(1 1)','POINT(1 1)');
intersection
SRID=-1;POINT(1 1)
(1 row)
Looks good. So I try isolating the line I think is causing the problems:
bayarea=# select a.stfid, multi(geomunion(a.the_geom, b.the_geom)) from
tr90 a, tr90 b where distance (a.the_geom, b.the_geom) = 0;
NOTICE: IllegalArgumentException: LinearRing not closed
NOTICE: IllegalArgumentException: geometries must not contain null
elements
ERROR: Couldnt convert the postgis geometry to GEOS!
Not good. But the really weird part is that when you repeat the GEOS
test, you get this:
NOTICE: AssertionFailedException: Should never reach here: Unknown
Precision Model type encountered
ERROR: GEOS Intersection() threw an error!
bayarea=#
The postmaster then no longer responds to an ordinary shutdown request,
and I have to kill -9 the process. Once restarted though, the GEOS test
is successful.
Any insight into my problems would be greatly appreciated. My hunch is
that it has something to do with the way Postgis and/or GEOS were
compiled, as I had to install and use GCC 3.4.1 (GCC 3.3 is standard
with OS 10.3, but it cannot compile Postgis 0.8.2.).
Michael Choy
Division of Epidemiology
Stanford University School of Medicine
