[postgis-users] ESRI and PostGis
Gregory S. Williamson
gsw at globexplorer.com
Wed Aug 11 14:41:56 PDT 2004
See
http://www.vividsolutions.com/jump/
It is a Java package, fairly easy to install on most OS (Macs may require a bit more futzing). There are a few plugins, including one for postGis (read only, I think, but it ltes save as a shapefile which can then be loaded in postgres). The postGis plugin requires version 1.1 of Jump (I think -- check the site for details).
Greg W.
-----Original Message-----
Sent: Wednesday, August 11, 2004 2:21 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] ESRI and PostGis
Great, but how does it work, the famous jump itÅ> downloadable?? thanks
El mié, 11-08-2004 a las 14:33, Gregory S. Williamson escribió:
> You can use a WMS service to show imagery in JUMP ...
> Greg Williamson
> DBA
> GlobeXplorer LLC
> From: Raghu Arni [mailto:arniraghu at gmail.com]
> Sent: Wed 8/11/2004 11:21 AM
> Cc:
> Subject: Re: [postgis-users] ESRI and PostGis
> I did try out Jump. But how do I load an image and overlay polygons
> and points on top of image and save the shapes.
> thx,
> Arni
> On Wed, 11 Aug 2004 18:20:31 +0200, Maurizio Napolitano <napo at itc.it> wrote:
> > > There are a lot of another FREE* solutions:
> > > - GRASS (you can do ALL! Editing a postgis layer)
> > > - QGIS (the next version - available on CVS - can edit vector layers)
> > > - Thuban (there is a plugin for the editing)
> > > - OpenEV (you can direct edit shape file)
> > > - GISToolkit (with a simple change on the source code for the
> > > GISEditor sample application you can edit and create ESRI shape file
> > > or postgis layers)
> > > - ... look to http://freegis.org
> > .... ops ...
> > and JUMP!
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
