[postgis-users] composite key index (again)
Charlton Purvis
cpurvis at asg.sc.edu
Wed Aug 11 20:23:06 PDT 2004
Hi, guys:
I know I've bugged y'all about this before, but for the life of me I can't remember what your 2 Canadian cents advice was. And that's worth a lot of USD! Paul, I think you threw me a bone earlier, but I can't find the thread neither physically nor mentally.
Say I have this snazzy table:
charlton (
my_time timestamp without time zone,
my_geom POINT
And say that every single MapServer query against this table is always done by selecting both time and space. I know I'll have to track down the order, but say I also magically figure out that it's always time and then space. (Actually that's the way it should be -- I've beem playing w/ the CLUSTER command, but unless I have the best indices around, it won't be of much use).
How can I create a composite key index w/ a timestamp without time zone column and a geometry column? Something akin to using a betree for the time and a gist for the geom. I know I can do a btree(my_time, my_geom), but that won't cut it for the && operator I don't think. However, doing a gist of the two gives me a friendly:
sea_coos_obs=# create index dang_index_doesnt_work on charlton using gist(my_time,my_geom);
ERROR: data type timestamp without time zone has no default operator class for access method "gist"
HINT: You must specify an operator class for the index or define a default operator class
I know the HINT actually means something to smart people. Also, I imagine I'd like to throw varchar in on the composite action.
Mind jogging my memory?
Thanks,
Charlton
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040811/5b369368/attachment.bin>
