[postgis-users] PostgreSQL 8.0 Beta Installer for Windows
TECHER Jean David
davidtecher at yahoo.fr
Fri Aug 13 01:34:29 PDT 2004
Hi Steffen
I downloaded the postgis installer you made... Great work :-)
Can you just add to your page
http://dcmms.sourceforge.net/postgis_installer.php
that
1. HOW TO USING POSTGIS
before create any database using PostGIS that users should replace in the file "share\contrib\postgis.sql"
'$libdir'
by the path to PostgreSQL installation (ex: C:/Postgresql ... and so on....)
2. AsSVG function and our names
Since there is the function AsSVG() avalable in this distribution (see http://svg.cc/pg/assvg/ for details)
just add my name TECHER Jean David
and KLAUS FOERSTER who has done this function...
Thanks ;-)
TECHER JEAN DAVID
- Responsable Informatique 01MAP -
e-mail:davidtecher at yahoo.fr
Tél: 06 85 37 36 75
Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]De la part de
> Steffen Macke
> Envoyé : jeudi 12 août 2004 16:03
> À : PostGIS Users Discussion
> Objet : Re: [postgis-users] PostgreSQL 8.0 Beta Installer for Windows
> Hello All,
> > I made a distribution from the cvs snapshot that pginstaller uses
> I've used this to create an Windows PostGIS installer
> that is compatible with the 8.0-beta1 PostgreSQL installer from
> http://pgfoundry.org/projects/pginstaller
> You can download the installer (PostGIS 0.8.2, GEOS 1.0.0, PROJ
> 4.4.7) from
> Install to the same directory where you installed PostgreSQL.
> PostGIS documentation in PDF and CHM format will be installed
> to the doc folder of the PostgreSQL installation.
> Don't get confused because the website and documentation
> are still talking about Cygwin - this will change soon.
> Steffen
> postgis-users mailing list
