[postgis-users] Postgres 8.0beta1 crashes when SELECTing using GIST index?
Dan R Greening greening at bigtribe.com
Sun Aug 15 08:28:09 PDT 2004
The following test SQL script crashes Postgres (the server) under the
Postgres 8.0beta1 Windows-installer plus PostGIS windows installer.  I
suspect it might actually be me using something I shouldn't, but could you
take a peek?  Yes, I loaded postgis.sql.
The crash occurs in the SELECT statement at the end.
CREATE TABLE poiloc (
  poiid varchar(11) NOT NULL UNIQUE,
  latitude DOUBLE PRECISION NOT NULL,
  longitude DOUBLE PRECISION NOT NULL,
  PRIMARY KEY  (poiid)
CREATE INDEX lat_index ON poiloc (latitude,longitude);
CREATE INDEX lon_index ON poiloc (longitude,latitude);
INSERT INTO poiloc (poiid, latitude, longitude) VALUES
('27165',37.766029,-122.430382);
('11',37.764894,-122.423022);
('12',37.764829,-122.423882);
('18',37.762529,-122.396481);
('19',37.761829,-122.418282);
('25',37.790508,-122.398332);
('26',37.788028,-122.395281);
SELECT AddGeometryColumn('poi','poiloc','geom',-1,'POINT', 2);
UPDATE poiloc set geom = GeometryFromText('POINT(' || latitude || ' ' ||
longitude || ')',
    -1);
CREATE INDEX geom_idx ON poiloc USING GIST(geom gist_geometry_ops);
select poiid from poiloc where geom && GeometryFromText('BOX3D(37.76930
-122.40798,37.78729 -122.38521)',-1);
Dan Greening, Ph.D.  CEO BigTribe http://dan.greening.name/contact.htm
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of postgis-users-request at postgis.refractions.net
> Sent: Sunday, August 15, 2004 8:09 AM
> To: greening at bigtribe.com
> Subject: Welcome to the "postgis-users" mailing list
> Welcome to the postgis-users at postgis.refractions.net mailing list!
> To post to this list, send your email to:
> General information about the mailing list is at:
>   http://postgis.refractions.net/mailman/listinfo/postgis-users
> If you ever want to unsubscribe or change your options (eg,
> switch to or from digest mode, change your password, etc.),
> visit your subscription page at:
> http://postgis.refractions.net/mailman/options/postgis-users/g
> reening%40bigtribe.com
> You can also make such adjustments via email by sending a message to:
> with the word `help' in the subject or body (don't include
> the quotes), and you will get back a message with instructions.
> You must know your password to change your options (including
> changing the password, itself) or to unsubscribe.  It is:
>   thingy
> Normally, Mailman will remind you of your
> postgis.refractions.net mailing list passwords once every
> month, although you can disable this if you prefer.  This
> reminder will also include instructions on how to unsubscribe
> or change your account options.  There is also a button on
> your options page that will email your current password to you.
