[postgis-users] Postgres 8.0beta1 crashes when SELECTing using GISTindex?
Dan R Greening
greening at bigtribe.com
Sun Aug 15 10:52:30 PDT 2004
The immediately following script (taken directly from
http://postgis.refractions.net/README.postgis.txt) also causes a crash in
the PostgreSQL 8.0beta1
CREATE TABLE geom_test ( gid int4, geom geometry,name varchar(25) );
INSERT INTO geom_test ( gid, geom, name )
VALUES ( 1, 'POLYGON((0 0 0,0 5 0,5 5 0,5 0 0,0 0 0))', '3D Square');
VALUES ( 2, 'LINESTRING(1 1 1,5 5 5,7 7 5)', '3D Line' );
VALUES ( 3, 'MULTIPOINT(3 4,8 9)', '2D Aggregate Point' );
SELECT * from geom_test WHERE geom && 'BOX3D(2 2 0,3 3 0)'::box3d;
Are others getting this to work OK? (In other words, should I suspect a bad
installation?)
Dan Greening, Ph.D. CEO BigTribe http://dan.greening.name/contact.htm
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Dan R Greening
> Sent: Sunday, August 15, 2004 8:28 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Postgres 8.0beta1 crashes when
> The following test SQL script crashes Postgres (the server)
> under the Postgres 8.0beta1 Windows-installer plus PostGIS
> windows installer. I suspect it might actually be me using
> something I shouldn't, but could you take a peek? Yes, I
> loaded postgis.sql.
> The crash occurs in the SELECT statement at the end.
> CREATE TABLE poiloc (
> poiid varchar(11) NOT NULL UNIQUE,
> latitude DOUBLE PRECISION NOT NULL,
> longitude DOUBLE PRECISION NOT NULL,
> PRIMARY KEY (poiid)
> CREATE INDEX lat_index ON poiloc (latitude,longitude); CREATE
> INDEX lon_index ON poiloc (longitude,latitude); INSERT INTO
> poiloc (poiid, latitude, longitude) VALUES
> ('27165',37.766029,-122.430382); INSERT INTO poiloc (poiid,
> latitude, longitude) VALUES ('11',37.764894,-122.423022);
> INSERT INTO poiloc (poiid, latitude, longitude) VALUES
> ('12',37.764829,-122.423882); INSERT INTO poiloc (poiid,
> latitude, longitude) VALUES ('18',37.762529,-122.396481);
> ('19',37.761829,-122.418282); INSERT INTO poiloc (poiid,
> latitude, longitude) VALUES ('25',37.790508,-122.398332);
> ('26',37.788028,-122.395281); SELECT
> AddGeometryColumn('poi','poiloc','geom',-1,'POINT', 2);
> UPDATE poiloc set geom = GeometryFromText('POINT(' ||
> latitude || ' ' || longitude || ')',
> -1);
> CREATE INDEX geom_idx ON poiloc USING GIST(geom
> gist_geometry_ops); select poiid from poiloc where geom &&
> GeometryFromText('BOX3D(37.76930
> -122.40798,37.78729 -122.38521)',-1);
> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> > postgis-users-request at postgis.refractions.net
> > Sent: Sunday, August 15, 2004 8:09 AM
> > To: greening at bigtribe.com
> > Subject: Welcome to the "postgis-users" mailing list
> > Welcome to the postgis-users at postgis.refractions.net mailing list!
> > To post to this list, send your email to:
> > General information about the mailing list is at:
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > If you ever want to unsubscribe or change your options (eg,
> switch to
> > or from digest mode, change your password, etc.), visit your
> > subscription page at:
> > http://postgis.refractions.net/mailman/options/postgis-users/g
> > reening%40bigtribe.com
> > You can also make such adjustments via email by sending a
> message to:
> > with the word `help' in the subject or body (don't include the
> > quotes), and you will get back a message with instructions.
> > You must know your password to change your options
> (including changing
> > the password, itself) or to unsubscribe. It is:
> > thingy
> > Normally, Mailman will remind you of your postgis.refractions.net
> > mailing list passwords once every month, although you can
> disable this
> > if you prefer. This reminder will also include
> instructions on how to
> > unsubscribe or change your account options. There is also
> a button on
> > your options page that will email your current password to you.
> postgis-users mailing list
