[postgis-users] PostGIS binairy from CVS for Windows Updates
Dan R Greening
greening at bigtribe.com
Mon Aug 16 21:50:14 PDT 2004
I got this error:
C:\Program Files\PostgreSQL\8.0-beta1\share\contrib>psql -f postgis.sql -d
poi -U bigtribe
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:postgis.sql:1863: ERROR: could not find function "assvg_geometry" in
file
"C:/Program Files/PostgreSQL/8.0-beta1/lib/libpostgis.dll"
psql:postgis.sql:1868: ERROR: current transaction is aborted, commands
ignored
until end of transaction block
ROLLBACK
Which apparently rolls back everything in postgis.sql. So I guess this
doesn't work?
Dan Greening, Ph.D. CEO BigTribe http://dan.greening.name/contact.htm
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Steffen Macke
> Sent: Monday, August 16, 2004 10:54 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS binairy from CVS for
> Windows Updates
> Dan (and other who would like to fix the crashes of the
> PostGIS Windows installer version):
> Download the zipfile below.
> > As usual You can download it at
> http://www.01map.com/download/postgis-082_geos-100_proj-447_assvg.zip
> Copy
> lib/libgeos.dll
> lib/libpostgis.dll
> lib/libproj.dll
> from the zipfile over the files of your existing PostGIS installation.
> You'll find them most probably under
> c:\program files\PostgreSQL\8.0-beta1\lib
> I prefer to release a new installer once PostGIS 0.83 is out.
> However, if this will take a long time, I'll create an
> intermediate 0.82+cvs version of the installer.
> Steffen
> postgis-users mailing list
