[postgis-users] RV: Distance Function
Paul Ramsey
pramsey at refractions.net
Wed Aug 18 09:46:54 PDT 2004
Dan R Greening wrote:
> t complains that the && operator is trying to compute overlap from two
> different geometries. But shouldn't it just perform a projection to make it
> work? Do I need to project this explicitly?
Yes, you do need to project explicitly. Given that we have proj, it is
possible we could now simply do the conversion as required (as a recall,
the check was included in postgis post-srid support, but pre-proj support).
> And what if I project to some
> geometry that requires additional parameters, such as referenced here:
> http://xserve.flids.com/pipermail/proj/2004-June/000086.html
EPSG numbers are supposed to include *all* information about a srs,
including datum information. If you find your EPSG information is not
sufficient, it is probably because the info in spatial_ref_sys is not
actually correct. As a stopgap, simply update the proj4text attribute in
your spatial_ref_sys entry to include the extra information you want (in
the example you cite, it is datum transform parameters, to_wgs84)
Paul
