[postgis-users] The operator && is not overlapsoperator basedonthe OGC SF SQL
David Blasby
dblasby at gmail.com
Wed Aug 18 10:55:30 PDT 2004
> This means that if one has only bounding boxes geometries then this is valid
> "geom && candidate" <=> "geom && candidate AND intersects(geom,candidate)"
No, this isnt correct.
You are absolutely correct, the "&&" is poorly named. This is for
historical reasons (the && operator was defined as "overlaps" by the
original postgresql geometry types). It would be better named
something like "MBR_intersects".
A documentation change should be made so this is more clear and doesnt
conflict with the OGC named relationship.
g1 && g2 <==> intersects ( envelope(g1) , envelope(g2) )
The "&&" is extreamly useful because its (1) fast and (more
importantly) (2) indexed.
Most of the time, you will do your query like this:
SELECT ... FROM ... WHERE the_geom && <geometry/bbox> AND <geometry op>;
The && is indexed (so its really fast) and will return an
"approximate" solution (all geometries whose bounding box intersects
the "search geometry's bounding box").
When you provide the "AND <geometry op>" portion, you refine the
approximate solution to the exact solution. For example, "AND
touches(the_geom, <geom>)" or "AND intersect(the_geom,<geom>)".
Since pulling millions of geometries off the disk is slow, and the
geometry operations are computationally intensive using the index
speeds things up!
NOTE: there are some situations where using "&&" isnt appropriate.
For example, "AND disjoint(the_geom,<geom>)" isnt going to be
effective because the "&&" approximate solution isnt correct.
Use "&&" when
geometry_op(the_geom,<geom>) ==> intersects(envelope(the_geom),
envelope(<geom>))
dave
