[postgis-users] Help: Ring not closed error when loading data via shp2pgsql
Wood Brent pcreso at pcreso.com
Mon Aug 23 22:30:39 PDT 2004
I have a shapefile to load into PostGIS.
When I run the SQL created with shp2pgsql, I get the following message,
psql:ross020107.sql:7: ERROR:  polygon has ring where first point != last point
followed by errors until the failed commit statement.
The polygons contain several rings & several thousand vertices, and I have
potentially a few hundred shapefiles to load.
Is there any way to give a more verbose error message to help identify the
erroneous Ring so I can edit in the closing coordinate pair.
Could the "7" help find the polygon? What does it refer to?
Any suggestions as to how I can get closer to identifying the offending
polygon/ring appreciated.
Thanks,
   Brent Wood
