[postgis-users] Help: Ring not closed error when loading data via shp2pgsql
Stephen Frost
sfrost at snowman.net
Tue Aug 24 05:21:45 PDT 2004
* Wood Brent (pcreso at pcreso.com) wrote:
> When I run the SQL created with shp2pgsql, I get the following message,
> psql:ross020107.sql:7: ERROR: polygon has ring where first point != last point
> followed by errors until the failed commit statement.
> Could the "7" help find the polygon? What does it refer to?
I *think* it might be the line number. :) Certainly, that's probably
the first thing I'd check.
> Any suggestions as to how I can get closer to identifying the offending
> polygon/ring appreciated.
Well, binary search is one approach to take. Only load half the file,
see if you get a problem or not, then load half the problem file, etc.
Stephen
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040824/1929d986/attachment.pgp>
