[postgis-users] Indexes (ENABLE_SEQSCAN)
Alexandre Florio
aflorio at gisplan.com.br
Thu Aug 26 10:42:38 PDT 2004
Analyzing the archives, this seems to be an exhaustively discussed problem which was apparently fixed in version 0.6.
The documentation says that I do not need, anymore, to use "SET ENABLE_SEQSCAN=OFF" to force the planner to use the spatial index. Nevertheless, I have a database in which a query do execute much faster when setting ENABLE_SEQSCAN to OFF.
Before dumping the table scheme, queries and outputs I would like to confirm that this should not happen in the current version of PostGIS (0.8.2).
Thanks,
Alexandre Florio
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040826/23d59f7c/attachment.pgp>
