[postgis-users] Indexes (ENABLE_SEQSCAN)
Paul Ramsey pramsey at refractions.net
Mon Aug 30 21:42:29 PDT 2004
Run "select update_geometry_stats();" and see if the planner does not
get smarter about whether or not to use the index.
P.
Alexandre Florio wrote:
> Analyzing the archives, this seems to be an exhaustively discussed
> problem which was apparently fixed in version 0.6.
> The documentation says that I do not need, anymore, to use "SET
> ENABLE_SEQSCAN=OFF" to force the planner to use the spatial index.
> Nevertheless, I have a database in which a query do execute much
> faster when setting ENABLE_SEQSCAN to OFF.
> Before dumping the table scheme, queries and outputs I would like to
> confirm that this should not happen in the current version of PostGIS
> (0.8.2).
> Thanks, Alexandre Florio
