[postgis-users] Large (and slow) Intersection
James McEachern
jamesm at threetier.com
Fri Aug 27 08:39:44 PDT 2004
We have the GIST index, and use a statement just like this
for each individual polygon.
Our problem is that there are hundreds of polygons, and we would
like to get a result with one statement. These polygons could
be in the four outer corners (but still very small in area),
which causes the the envelope to be large.
An example of the statement
SELECT points.the_geom
FROM points
WHERE points.the_geom &&
(SELECT geomunion(polys.the_geom) from polys
somekeyfield = "KEYVALUE')
AND withing(points.the_geom,
somekeyfield = "KEYVALUE'));
Now this works when the polygons are close together
geographically, but when they are wildly spaced over the
whole area, the && condition really returns all of the
points.
The obvious solution is to first to first select all of the
individual polys (no union), and then iteratively call your
SELECT for each polygon returned.
SELECT polys.the_geom from polys WHERE somekeyfield = "KEYVALUE';
foreach (poly in polyresult)
FROM points
WHERE points.the_geom && poly
AND withing(points.the_geom, poly);
// keep track of the results of each iteration
This gives the result quickly, but is more complex and more hits against
the database.
thanks,
jamesm
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
strk at refractions.net
Sent: Friday, August 27, 2004 2:17 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Large (and slow) Intersection
I did not understand your problem, does this query do what you need ?
FROM points, polys
WHERE points.the_geom && polys.the_geom
AND withing(points.the_geom, polys.the_geom);
--strk;
On Fri, Aug 27, 2004 at 01:20:29AM -0600, James McEachern wrote:
> Hi All,
> We are trying to locate point objects that fall within polygon objects.
> Our data points are spread out over a large area, and the polygons
> used to locate may be spread over an equally large area, but only
> would have a very small coverage (< 1% of total area)
> There are ~500K point objects, and upwards of 1000 polygons.
> Of course if we union the polygons together, the resulting envelope
> used for the && operation basically gets all of the points.
> And this would run for ever.
> By doing the query on any single polygon with the && and intersection,
> we get the correct result very fast, therefore running it for 1000
> polygons, it would take around ~1000 seconds. Quite manageable.
> I have seen previous posts regarding this problem/solution, and they
> used an iterative solution, to walk over the polygon result set (in
> code) doing each && intersection independently and summing (actually
> unioning) the results. Creating a stored proc looks like one solution.
> I am looking for a correlated sub-query (or something) to get the
> result.
> Does anyone know if a single (correlated) query is possible?
> Thanks,
> James S McEachern
> Geo Webworks Inc.
> 2020, 801 6 Avenue SW
> Calgary, Alberta
> T2P 3W2
> 403-301-4001
> postgis-users mailing list
