[postgis-users] Large (and slow) Intersection
Paul Ramsey
pramsey at refractions.net
Fri Aug 27 10:06:19 PDT 2004
I don't understand why you are not using the simple SQL for this
problem:
select points.the_geom
from points, polys
where
points.the_geom && polys.the_geom
and
polys.keyfield = 'KEYVALUE'
and
within(points.the_geom,polys.the_geom)
Make sure you have USE_STATS turned on and have run select
update_geometry_stats(), (or if you are in 8.0 land, have simply run
vacuum analyze (i love that)).
On Friday, August 27, 2004, at 08:39 AM, James McEachern wrote:
> We have the GIST index, and use a statement just like this
> for each individual polygon.
> Our problem is that there are hundreds of polygons, and we would
> like to get a result with one statement. These polygons could
> be in the four outer corners (but still very small in area),
> which causes the the envelope to be large.
> An example of the statement
> SELECT points.the_geom
> FROM points
> WHERE points.the_geom &&
> (SELECT geomunion(polys.the_geom) from polys
> somekeyfield = "KEYVALUE')
> AND withing(points.the_geom,
> somekeyfield = "KEYVALUE'));
> Now this works when the polygons are close together
> geographically, but when they are wildly spaced over the
> whole area, the && condition really returns all of the
> points.
> The obvious solution is to first to first select all of the
> individual polys (no union), and then iteratively call your
> SELECT for each polygon returned.
> SELECT polys.the_geom from polys WHERE somekeyfield = "KEYVALUE';
> foreach (poly in polyresult)
> FROM points
> WHERE points.the_geom && poly
> AND withing(points.the_geom, poly);
> // keep track of the results of each iteration
> This gives the result quickly, but is more complex and more hits
> against
> the database.
> thanks,
> jamesm
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> strk at refractions.net
> Sent: Friday, August 27, 2004 2:17 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Large (and slow) Intersection
> I did not understand your problem, does this query do what you need ?
> FROM points, polys
> WHERE points.the_geom && polys.the_geom
> AND withing(points.the_geom, polys.the_geom);
> --strk;
> On Fri, Aug 27, 2004 at 01:20:29AM -0600, James McEachern wrote:
>> Hi All,
>> We are trying to locate point objects that fall within polygon
>> objects.
>> Our data points are spread out over a large area, and the polygons
>> used to locate may be spread over an equally large area, but only
>> would have a very small coverage (< 1% of total area)
>> There are ~500K point objects, and upwards of 1000 polygons.
>> Of course if we union the polygons together, the resulting envelope
>> used for the && operation basically gets all of the points.
>> And this would run for ever.
>> By doing the query on any single polygon with the && and intersection,
>> we get the correct result very fast, therefore running it for 1000
>> polygons, it would take around ~1000 seconds. Quite manageable.
>> I have seen previous posts regarding this problem/solution, and they
>> used an iterative solution, to walk over the polygon result set (in
>> code) doing each && intersection independently and summing (actually
>> unioning) the results. Creating a stored proc looks like one solution.
>> I am looking for a correlated sub-query (or something) to get the
>> result.
>> Does anyone know if a single (correlated) query is possible?
>> Thanks,
>> James S McEachern
>> Geo Webworks Inc.
>> 2020, 801 6 Avenue SW
>> Calgary, Alberta
>> T2P 3W2
>> 403-301-4001
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
