[postgis-users] spatial update SQL
Paul Ramsey
pramsey at refractions.net
Mon Aug 30 21:37:38 PDT 2004
This is going to sound "anti-database", but:
write a perl script that does
foreach cell
SQL to get average value
SQL to update
As long as your 20M record table is properly indexed, so that the
average value number comes back really fast, and you make good use of
prepared statements and statements handles, this can go extremely quickly.
I used this technique to collapse a 50M record table to a 3M record
table, doing a fair amount of analysis in each iteration (a little time
series analysis for each of the 3M new records). It took a shade under
an hour.
Trying to do it in one SQL statement might prove counter-productive.
Paul
Wood Brent wrote:
> Hopefully someone can help with a SQL how-to.
> I have two tables with geometries. One has 150,000 square cells as polygons as
> well as an empty depth attribute. The other table has 20,000,000 point depths,
> derived from a global topography dataset.
> I want to update the depth attribute for each cell record with the average
> value of all the depth points lying within each cell.
> I'm sure there should be a way to do this in a single pass, but I can't see it.
> I can extract the cell.gid & avg(point.depth) to a text file or another table
> with a simple sql, then use this to run the update, but this seems unecessary
> overhead.
> Given the numbers of records in each table, I'm also interested in any ways to
> improve the performance of the query, apart from adding more memory :-)
> Any suggestions appreciated.
> Brent Wood
> postgis-users mailing list
