[postgis-users] spatial update SQL
Wood Brent pcreso at pcreso.com
Tue Aug 31 00:39:02 PDT 2004
--- Paul Ramsey <pramsey at refractions.net> wrote:
> This is going to sound "anti-database", but:
Not at all, anti SQL perhaps, but the DB does what is needed just fine. SQL
alone is not always the answer :-)
> write a perl script that does
I plan to learn perl sometime this year, but I figure a shell script will do
about the same thing, if slower.
> foreach cell
>    SQL to get average value
>    SQL to update
> As long as your 20M record table is properly indexed, so that the
> average value number comes back really fast, and you make good use of
> prepared statements and statements handles, this can go extremely quickly.
Um, those sound like some of the perl things I need to learn :-)
> I used this technique to collapse a 50M record table to a 3M record
> table, doing a fair amount of analysis in each iteration (a little time
> series analysis for each of the 3M new records). It took a shade under
> an hour.
So a simple shell script along the lines of the following should be reasonable?
(given that the geometry attrs and gid are indexed & the tables vacuum
analysed)
Any optimisations you can suggest? Speed is not a huge issue, as long as it's
not into days :-)
Thanks,
  Brent
DB=<database>
MAX=`psql $DB -q -t -c "select max(gid) from table;"`
COUNTER=`psql $DB -q -t -c "select min(gid) from table;"`
while [ $COUNTER -le $MAX ] ; do
  AVG=`psql $DB -q -t -c "select avg(depth)
                          from bathy_points b, cells c
                          where c.gid=$COUNTER
                            and b.the_geom && c.the_geom;"`
  psql -q -t -c "update cells
                 set depth $AVG
                 where gid = $COUNTER ;"
  COUNTER=`expr $COUNTER + 1`
done
