[postgis-users] spatial update SQL
Paul Ramsey
pramsey at refractions.net
Tue Aug 31 08:49:41 PDT 2004
Try this as it stands and see how fast it runs. You'll be spawning psql
and reconnecting a lot, which will cost you some speed. This is where
using perl/python/php and real connection handles would save you some
time. Also if you do you your update inside a transaction and batch your
commits every 100-1000 statements, you will speed things up a bit
(although it is possible you could get a deadlock, selecting from the
table while you are updating it, since the spatial index locks are table
locks, so maybe one at a time is better, best to try and see). Oh, on
the perl/python/php front, I found that opening two connections, one for
reading and one for writing, was a nice performance booster, rather than
running all my statements on the same connection.
Wood Brent wrote:
> Any optimisations you can suggest? Speed is not a huge issue, as long as it's
> not into days :-)
> Thanks,
> Brent
> DB=<database>
> MAX=`psql $DB -q -t -c "select max(gid) from table;"`
> COUNTER=`psql $DB -q -t -c "select min(gid) from table;"`
> while [ $COUNTER -le $MAX ] ; do
> AVG=`psql $DB -q -t -c "select avg(depth)
> from bathy_points b, cells c
> where c.gid=$COUNTER
> and b.the_geom && c.the_geom;"`
> psql -q -t -c "update cells
> set depth $AVG
> where gid = $COUNTER ;"
> COUNTER=`expr $COUNTER + 1`
> done
> postgis-users mailing list
