[postgis-users] spatial update SQL
David Blasby dblasby at gmail.com
Tue Aug 31 09:35:49 PDT 2004
> MAX=`psql $DB -q -t -c "select max(gid) from table;"`
> COUNTER=`psql $DB -q -t -c "select min(gid) from table;"`
> while [ $COUNTER -le $MAX ] ; do
>  AVG=`psql $DB -q -t -c "select avg(depth)
>                          from bathy_points b, cells c
>                          where c.gid=$COUNTER
>                            and b.the_geom && c.the_geom;"`
>  psql -q -t -c "update cells
>                 set depth $AVG
>                 where gid = $COUNTER ;"
>  COUNTER=`expr $COUNTER + 1`
Wouldnt it be easier just to do:
update cells set depth =
       select avg(depth)
        FROM bathy_points
                  WHERE bathy_points.the_geom && cells.the_geom
Sub-queries are your friend!
dave
