[postgis-users] overlap query
Jerod Clabaugh jclabaugh at mac.com
Tue Aug 31 14:52:17 PDT 2004
All:
I am trying to determine the amount (in hectares) of 1 or more
protected areas (parks) that overlap a watershed.
basically, what amount in hectares of a watershed that is protected
(falls within protected areas).  Both the Protected Areas layer
(shape_pa) and Watershed Layer (shape_watershed) are polygon layers
(multipolygon) and have OID and GIST indexes.  They also have the
same SRID.
Though this doesn't calculate the hectares yet, so far its returning nil.
SELECT  shape_pa.name, shape_pa.the_geom from shape_watershed, shape_pa
WHERE (shape_watershed.the_geom && shape_pa.the_geom) AND
area2d(intersection(geometryn(shape_watershed.the_geom,0),geometryn(shape_pa.the_geom,0))) >
0 AND shape_watershed.name = 'Belize River'
I was hoping this query would return the name of the protected areas
that overlap the watershed and their the_geom columns. Once I got
that far then I'd use it as a subquery to then calculate the hectares
as:
SELECT sum(area(shape_pa.the_geom))/10000 as hectares FROM
above query
Any thoughts on why this isn't working?
Cheers,
Jerod Clabaugh
Belize Biodiversity Mapping Service
http://www.iwlearn.net/belize
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040831/b9f3e52d/attachment.html>
