[postgis-users] spatial update SQL
David Blasby
dblasby at gmail.com
Tue Aug 31 16:30:23 PDT 2004
> > update celltable set celltable.value =
> > SELECT avg( point.value ) from point where celltable.the_geom &&
> > point.the_geom and contains(celltable.the_geom,point.the_geom)
This goes through the celltable, row by row. It updates the
celltable.value by executing the subquery, filling in
"celltable.the_geom" with the value FROM THE CURRENT ROW.
So, if celltable looks like this:
the_geom
<rectangle 1>
<rectangle 2>
As above query goes through the table, and will execute these two sub-queries:
SELECT avg( point.value ) from point where <rectangle 1> &&
point.the_geom and contains(<rectangle 1>,point.the_geom);
SELECT avg( point.value ) from point where <rectangle 2> &&
point.the_geom and contains(<rectangle 2>,point.the_geom);
Its all magic!
dave
