[postgis-users] library loading error
Paul Ramsey
pramsey at refractions.net
Wed Dec 1 10:59:29 PST 2004
Is /usr/local/lib in your /etc/ld.so.conf file?
If not, add it, and run ldconfig. All will work properly, permanently.
P
On 1-Dec-04, at 10:57 AM, collin wrote:
> When I rebooted this morning, downloaded FC3 kernel source to help
> with compiling madwifi, I now find that postgresql is _again_ no
> longer recognizing libgeos?!
> Is there something more permanent I need to do than doing ldconfig
> /usr/lib as root?
> Collin
> collin wrote:
>> I ran ldconfig -v. liblwgeom.so.1.0 was found, but libgeos.so.2.0.1
>> was not. I guess I may not have run it after all for /usr/local/lib.
>> So I ran it with /usr/local/lib.
>> After adding local/lib and rebooting, postgresql is now recognizing
>> geometries properly. Thanks!
>> Collin
>> strk at refractions.net wrote:
>>> On Tue, Nov 30, 2004 at 08:51:20AM -0800, collin wrote:
>>>> No, I ran it after geos,proj4,postgresql install, but before
>>>> postgis install. Then I ran it again after postgis install.
>>>> Should I have run it immediately after geos install?
>>> No. But you did have to run it.
>>> ldconfig -v gives you a list of 'found' libraries (under Linux)
>>> --strk;
>>>> Collin
>>>>> run ldconfig after GEOS install ?
>>>>> --strk;
>>>>> On Tue, Nov 30, 2004 at 07:56:00AM -0800, collin wrote:
>>>>>> Greetings,
>>>>>> I have compiled postgresql 8.0beta5, geos2.0.1, proj 4.4.9, and
>>>>>> postgis
>>>>>> form cvs (11/26) successfully on Fedora Core 3.
>>>>>> I have loaded a number or datasets into the database (sample lidar
>>>>>> points) and run gist, viewed with jump, etc without a problem.
>>>>>> After a round of Up2Date updates however, this morning I have
>>>>>> received
>>>>>> the following error:
>>>>>> ERROR: could not load library
>>>>>> "/usr/local/pgsql/lib/liblwgeom.so.1.0":
>>>>>> libgeos.so.2: cannot open shared object file: No such file or
>>>>>> directory
>>>>>> This occurs any time I try to select or operate on any table with
>>>>>> geometry.
>>>>>> I tried ldconfig /usr/local/pgsql/lib/, and i have
>>>>>> $LD_LIBRARY_PATH = /usr/local/pgsql/lib/ in my master startup
>>>>>> profile. Despite this, it still throws the error.
>>>>>> Any ideas?
>>>>>> Thanks,
>>>>>> Collin Bode
>>>>>> GIS Informatics Researcher
>>>>>> UC Berkeley
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at postgis.refractions.net
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
