[postgis-users] Elevation Profiles
ANDREW WOOLEY AWOOLEY at mountainland.org
Thu Dec 2 07:04:21 PST 2004
I am using pgsql 7.3.6 and postgis 0.8 on linux.
I will upgrade both and try it again.
Thanks for your help.
Andrew
>>> carl.anderson at vadose.org 12/1/2004 9:14:19 PM >>>
On 12/01/2004 05:47:47 PM, ANDREW WOOLEY wrote:
> Carl,
> Thanks for that.  It sounds like it will work very well, but I keep
> getting an error:
> WARNING: plpgsql: ERROR during compile of linestring_samples near
> line
> 23
> ERROR:  syntax error at or near "[".
I am testing your snippet here with my approximation of what your
tables are.
I don't (yet) find anything cooresponding to your issue of
WARNING: plpgsql: ERROR during compile of linestring_samples near line
23
BUT your calling script is using an increment of 0 to walk the path
position = position + 0;   as an iterator is not going to get
anywhere.
While i'm trying to track down your issues ......
  i am using postgresql 7.4.5 and postgis 0.9.0 on (linux) FC3
if you don't mind what is your platform and SW version?
I'll stick with you to get this going.
C.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
