[postgis-users] Elevation Profiles
ANDREW WOOLEY
AWOOLEY at mountainland.org
Fri Dec 3 10:11:38 PST 2004
Carl,
That returns the same error. I am hoping to upgrade over the weekend
and will get back on this early next week.
Thanks again for working with me on this.
Andrew
>>> carl.anderson at vadose.org 12/2/2004 6:48:24 PM >>>
On 12/02/2004 10:04:21 AM, ANDREW WOOLEY wrote:
> I am using pgsql 7.3.6 and postgis 0.8 on linux.
> I will upgrade both and try it again.
> Thanks for your help.
> Andrew
Andrew my functions use the array type (text[] an array of text) ,
which IIRC was not fully functional in Postgres 7.3.x.
but try the inner function only before upgrading
select * from linestring_sample((select the_geom from mtn_trails where
gid =3),10,0);
because if it works then cut and paste of scripts has introduced an
error.
i don't think you'ld have to upgrade PostGIS but if you do consider
upgrading GEOS at the same time.
C.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
