[postgis-users] Problem compiling postgis 0.8.2
SIGéal
sigeal at sigeal.fr
Fri Dec 10 03:00:56 PST 2004
I changed to postgis 0.9.0 and everything work all right.
Thanks.
Christophe Damour (SIGéal)
"Chez Charles"
16480 Saint Laurent des Combes
Téléphone : 05 45 98 36 06
Télécopie : 05 45 98 36 07
Courriel : sigeal at sigeal.fr
strk at refractions.net a écrit :
> On Thu, Dec 09, 2004 at 10:42:43PM +0100, SIGéal wrote:
>>Hi,
>>I am trying to compile Postgis 0.8.2 with geos 2.1.0 support against
>>postgresql 7.4.5, and I get the following error message :
>>gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
>>-Wmissing-declarations -g -fexceptions -I. -DFRONTEND
>>-DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUSE_VERSION=74
>>-I/usr/local/include/geos -DUSE_GEOS -I/usr/include -DUSE_PROJ
>>-DUSE_STATS -fpic -I../../src/include -D_GNU_SOURCE -c -o
>>postgis_geos.o postgis_geos.c
>>postgis_geos.c:274: attention : `resize_ptrArrayType' defined but not used
>>g++ -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
>>-I/usr/local/include/geos -DUSE_GEOS -I/usr/include -DUSE_PROJ -fPIC
>>-I../../src/include -D_GNU_SOURCE -c -o postgis_geos_wrapper.o
>>postgis_geos_wrapper.cpp
>>cc1plus: attention : "-Wmissing-declarations" is valid for C/ObjC but
>>not for
>> C++
>>postgis_geos_wrapper.cpp: Dans function « geos::Geometry*
>> PostGIS2GEOS_box3d(BOX3D*, int) »:
>>postgis_geos_wrapper.cpp:197: error: `BasicCoordinateList' undeclared (first
>> use this function)
>>postgis_geos_wrapper.cpp:197: error: (Each undeclared identifier is reported
>> only once for each function it appears in.)
>>I suspect a path problem, but can't manage to identify it. My Postgresql
>>source tree is under /var/tmp/postgis-0.8.2/work/postgresql-7.4.5/
>>Postgresql compiled ok. I then untar postgis-8.2.0.tar.gz in the contrib
>>directory.
> Postgis 0.8 does not work with GEOS-2.x.x
> Downgrage geos or upgrade postgis to 0.9.x
>>What does -DSYSCONFDIR='"/usr/local/pgsql/etc"' mean ? I don't have such
>>a directory...
> Nothing.. the directive is no more there as from CVS version
> --strk;
>>I cared to configure postgresql with LDFLAGS=-lstdc++
>>I modified postgis Makefile according to my proj and geos directories
>>Any help appreciated. Thanks in advance.
>>SIGéal
>>"Chez Charles"
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
