[postgis-users] shp2pgsql, pb with append
    strk at refractions.net
    Fri Dec 10 14:02:26 PST 2004
On Fri, Dec 10, 2004 at 10:37:09AM +0100, strk at refractions.net wrote:
> On Fri, Dec 10, 2004 at 10:29:47AM +0100, "Guillaume SUEUR (Géosignal)" wrote:
> > Hi,
> > When I use shp2pgsql with -a option to append the records to an existing
> > table, the script doesn't include the id fields in the fields list but
> > it does for the values list. And so the insert is incorrect :
> > INSERT INTO "geocomm" ("code","nom","dep",the_geom) VALUES
> > ('1','97209','Fort-de-France','972',GeometryFromText('MULTIPOLYGON(((....
> > See : 4 fields and 5 values !
> > I'm still using postGIS 0.8, is that fixed in version 0.9 ?
> Yes, removing the id from the VALUES, as it should have its own
> sequence generating unique ids for appended values.
Oops.. sorry. I found out it didn't go to 0.9.0.
You need a snapshot of the pgis_0_9_0 branch or
must wait for 0.9.1.
--strk;
> > Thanks
> Thank you
> --strk;
> > Guillaume SUEUR
> > GEOSIGNAL - Groupe BVA
> > 25bis Avenue Marcel Dassault
> > 31505 TOULOUSE CEDEX 5
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
