[postgis-users] problem occured when installing postgis,help me
boo hou
houboo2001 at yahoo.com.cn
Tue Dec 28 20:22:49 PST 2004
The problem occured at the moment when i execute #psql
-d mydb -f /usr/local/pgsql/share/postgis/sql, the
transactions were aborted. Then i resort the errors
into a file to trace the reason. What i got is as
follows. It's sure pl/pgsql is installed. So what's
wrong with it? Please help me. Thanx in advance!
BEGIN
message
PL/PgSQL is installed.
(1 row)
COMMIT
psql:postgis.sql:47: NOTICE: type "histogram2d" is
not yet defined
DETAIL: Creating a shell type definition.
psql:postgis.sql:47: ERROR: could not load library
"/usr/local/pgsql/lib/libpostgis.so.0.9":
libgeos.so.2: cannot open shared object file: No such
file or directory
psql:postgis.sql:52: ERROR: current transaction is
aborted, commands ignored until end of transaction
block
psql:postgis.sql:60: ERROR: current transaction is
block
psql:postgis.sql:77: ERROR: current transaction is
block
psql:postgis.sql:82: ERROR: current transaction is
block
psql:postgis.sql:89: ERROR: current transaction is
block
psql:postgis.sql:106: ERROR: current transaction is
block
psql:postgis.sql:111: ERROR: current transaction is
block
psql:postgis.sql:118: ERROR: current transaction is
block
psql:postgis.sql:135: ERROR: current transaction is
block
psql:postgis.sql:140: ERROR: current transaction is
block
psql:postgis.sql:146: ERROR: current transaction is
block
psql:postgis.sql:151: ERROR: current transaction is
block
psql:postgis.sql:163: ERROR: current transaction is
block
psql:postgis.sql:180: ERROR: current transaction is
block
psql:postgis.sql:185: ERROR: current transaction is
block
psql:postgis.sql:193: ERROR: current transaction is
block
psql:postgis.sql:210: ERROR: current transaction is
block
psql:postgis.sql:215: ERROR: current transaction is
block
psql:postgis.sql:233: ERROR: current transaction is
block
psql:postgis.sql:260: ERROR: current transaction is
block
psql:postgis.sql:271: ERROR: current transaction is
block
psql:postgis.sql:293: ERROR: current transaction is
block
psql:postgis.sql:301: ERROR: current transaction is
block
psql:postgis.sql:305: ERROR: current transaction is
block
psql:postgis.sql:309: ERROR: current transaction is
block
psql:postgis.sql:313: ERROR: current transaction is
block
psql:postgis.sql:317: ERROR: current transaction is
block
psql:postgis.sql:321: ERROR: current transaction is
block
psql:postgis.sql:325: ERROR: current transaction is
block
psql:postgis.sql:368: ERROR: current transaction is
block
psql:postgis.sql:407: ERROR: current transaction is
block
psql:postgis.sql:414: ERROR: current transaction is
block
psql:postgis.sql:447: ERROR: current transaction is
block
psql:postgis.sql:572: ERROR: current transaction is
block
psql:postgis.sql:685: ERROR: current transaction is
block
psql:postgis.sql:705: ERROR: current transaction is
block
psql:postgis.sql:724: ERROR: current transaction is
block
psql:postgis.sql:747: ERROR: current transaction is
block
psql:postgis.sql:753: ERROR: current transaction is
block
psql:postgis.sql:764: ERROR: current transaction is
block
psql:postgis.sql:769: ERROR: current transaction is
block
psql:postgis.sql:774: ERROR: current transaction is
block
psql:postgis.sql:779: ERROR: current transaction is
block
psql:postgis.sql:784: ERROR: current transaction is
block
psql:postgis.sql:789: ERROR: current transaction is
block
psql:postgis.sql:794: ERROR: current transaction is
block
psql:postgis.sql:799: ERROR: current transaction is
block
psql:postgis.sql:804: ERROR: current transaction is
block
psql:postgis.sql:809: ERROR: current transaction is
block
psql:postgis.sql:814: ERROR: current transaction is
block
psql:postgis.sql:819: ERROR: current transaction is
block
psql:postgis.sql:824: ERROR: current transaction is
block
psql:postgis.sql:829: ERROR: current transaction is
block
psql:postgis.sql:834: ERROR: current transaction is
block
psql:postgis.sql:839: ERROR: current transaction is
block
psql:postgis.sql:848: ERROR: current transaction is
block
psql:postgis.sql:853: ERROR: current transaction is
block
psql:postgis.sql:858: ERROR: current transaction is
block
psql:postgis.sql:863: ERROR: current transaction is
block
psql:postgis.sql:868: ERROR: current transaction is
block
psql:postgis.sql:873: ERROR: current transaction is
block
psql:postgis.sql:878: ERROR: current transaction is
block
psql:postgis.sql:883: ERROR: current transaction is
block
psql:postgis.sql:888: ERROR: current transaction is
block
psql:postgis.sql:893: ERROR: current transaction is
block
psql:postgis.sql:899: ERROR: current transaction is
block
psql:postgis.sql:904: ERROR: current transaction is
block
psql:postgis.sql:909: ERROR: current transaction is
block
psql:postgis.sql:914: ERROR: current transaction is
block
psql:postgis.sql:919: ERROR: current transaction is
block
psql:postgis.sql:924: ERROR: current transaction is
block
psql:postgis.sql:930: ERROR: current transaction is
block
psql:postgis.sql:935: ERROR: current transaction is
block
psql:postgis.sql:941: ERROR: current transaction is
block
psql:postgis.sql:946: ERROR: current transaction is
block
psql:postgis.sql:951: ERROR: current transaction is
block
psql:postgis.sql:956: ERROR: current transaction is
block
psql:postgis.sql:962: ERROR: current transaction is
block
psql:postgis.sql:967: ERROR: current transaction is
block
psql:postgis.sql:972: ERROR: current transaction is
block
psql:postgis.sql:977: ERROR: current transaction is
block
psql:postgis.sql:982: ERROR: current transaction is
block
psql:postgis.sql:987: ERROR: current transaction is
block
psql:postgis.sql:994: ERROR: current transaction is
block
psql:postgis.sql:999: ERROR: current transaction is
block
psql:postgis.sql:1014: ERROR: current transaction is
block
psql:postgis.sql:1019: ERROR: current transaction is
block
psql:postgis.sql:1024: ERROR: current transaction is
block
psql:postgis.sql:1030: ERROR: current transaction is
block
psql:postgis.sql:1035: ERROR: current transaction is
block
psql:postgis.sql:1040: ERROR: current transaction is
block
psql:postgis.sql:1045: ERROR: current transaction is
block
psql:postgis.sql:1050: ERROR: current transaction is
block
psql:postgis.sql:1055: ERROR: current transaction is
block
psql:postgis.sql:1060: ERROR: current transaction is
block
psql:postgis.sql:1065: ERROR: current transaction is
block
psql:postgis.sql:1070: ERROR: current transaction is
block
psql:postgis.sql:1075: ERROR: current transaction is
block
psql:postgis.sql:1080: ERROR: current transaction is
block
psql:postgis.sql:1085: ERROR: current transaction is
block
psql:postgis.sql:1090: ERROR: current transaction is
block
psql:postgis.sql:1095: ERROR: current transaction is
block
psql:postgis.sql:1100: ERROR: current transaction is
block
psql:postgis.sql:1105: ERROR: current transaction is
block
psql:postgis.sql:1110: ERROR: current transaction is
block
psql:postgis.sql:1115: ERROR: current transaction is
block
psql:postgis.sql:1120: ERROR: current transaction is
block
psql:postgis.sql:1125: ERROR: current transaction is
block
psql:postgis.sql:1130: ERROR: current transaction is
block
psql:postgis.sql:1135: ERROR: current transaction is
block
psql:postgis.sql:1141: ERROR: current transaction is
block
psql:postgis.sql:1146: ERROR: current transaction is
block
psql:postgis.sql:1151: ERROR: current transaction is
block
psql:postgis.sql:1156: ERROR: current transaction is
block
psql:postgis.sql:1161: ERROR: current transaction is
block
psql:postgis.sql:1166: ERROR: current transaction is
block
psql:postgis.sql:1171: ERROR: current transaction is
block
psql:postgis.sql:1176: ERROR: current transaction is
block
psql:postgis.sql:1182: ERROR: current transaction is
block
psql:postgis.sql:1187: ERROR: current transaction is
block
psql:postgis.sql:1192: ERROR: current transaction is
block
psql:postgis.sql:1197: ERROR: current transaction is
block
psql:postgis.sql:1202: ERROR: current transaction is
block
psql:postgis.sql:1207: ERROR: current transaction is
block
psql:postgis.sql:1212: ERROR: current transaction is
block
psql:postgis.sql:1217: ERROR: current transaction is
block
psql:postgis.sql:1222: ERROR: current transaction is
block
psql:postgis.sql:1227: ERROR: current transaction is
block
psql:postgis.sql:1233: ERROR: current transaction is
block
psql:postgis.sql:1238: ERROR: current transaction is
block
psql:postgis.sql:1243: ERROR: current transaction is
block
psql:postgis.sql:1248: ERROR: current transaction is
block
psql:postgis.sql:1253: ERROR: current transaction is
block
psql:postgis.sql:1258: ERROR: current transaction is
block
psql:postgis.sql:1263: ERROR: current transaction is
block
psql:postgis.sql:1268: ERROR: current transaction is
block
psql:postgis.sql:1273: ERROR: current transaction is
block
psql:postgis.sql:1278: ERROR: current transaction is
block
psql:postgis.sql:1284: ERROR: current transaction is
block
psql:postgis.sql:1289: ERROR: current transaction is
block
psql:postgis.sql:1295: ERROR: current transaction is
block
psql:postgis.sql:1305: ERROR: current transaction is
block
psql:postgis.sql:1310: ERROR: current transaction is
block
psql:postgis.sql:1315: ERROR: current transaction is
block
psql:postgis.sql:1324: ERROR: current transaction is
block
psql:postgis.sql:1329: ERROR: current transaction is
block
psql:postgis.sql:1334: ERROR: current transaction is
block
psql:postgis.sql:1339: ERROR: current transaction is
block
psql:postgis.sql:1344: ERROR: current transaction is
block
psql:postgis.sql:1349: ERROR: current transaction is
block
psql:postgis.sql:1354: ERROR: current transaction is
block
psql:postgis.sql:1364: ERROR: current transaction is
block
psql:postgis.sql:1369: ERROR: current transaction is
block
psql:postgis.sql:1374: ERROR: current transaction is
block
psql:postgis.sql:1379: ERROR: current transaction is
block
psql:postgis.sql:1384: ERROR: current transaction is
block
psql:postgis.sql:1389: ERROR: current transaction is
block
psql:postgis.sql:1394: ERROR: current transaction is
block
psql:postgis.sql:1404: ERROR: current transaction is
block
psql:postgis.sql:1409: ERROR: current transaction is
block
psql:postgis.sql:1414: ERROR: current transaction is
block
psql:postgis.sql:1419: ERROR: current transaction is
block
psql:postgis.sql:1424: ERROR: current transaction is
block
psql:postgis.sql:1429: ERROR: current transaction is
block
psql:postgis.sql:1434: ERROR: current transaction is
block
psql:postgis.sql:1443: ERROR: current transaction is
block
psql:postgis.sql:1448: ERROR: current transaction is
block
psql:postgis.sql:1454: ERROR: current transaction is
block
psql:postgis.sql:1459: ERROR: current transaction is
block
psql:postgis.sql:1465: ERROR: current transaction is
block
psql:postgis.sql:1470: ERROR: current transaction is
block
psql:postgis.sql:1477: ERROR: current transaction is
block
psql:postgis.sql:1487: ERROR: current transaction is
block
psql:postgis.sql:1492: ERROR: current transaction is
block
psql:postgis.sql:1497: ERROR: current transaction is
block
psql:postgis.sql:1502: ERROR: current transaction is
block
psql:postgis.sql:1507: ERROR: current transaction is
block
psql:postgis.sql:1512: ERROR: current transaction is
block
psql:postgis.sql:1517: ERROR: current transaction is
block
psql:postgis.sql:1522: ERROR: current transaction is
block
psql:postgis.sql:1531: ERROR: current transaction is
block
psql:postgis.sql:1536: ERROR: current transaction is
block
psql:postgis.sql:1541: ERROR: current transaction is
block
psql:postgis.sql:1546: ERROR: current transaction is
block
psql:postgis.sql:1551: ERROR: current transaction is
block
psql:postgis.sql:1556: ERROR: current transaction is
block
psql:postgis.sql:1565: ERROR: current transaction is
block
psql:postgis.sql:1570: ERROR: current transaction is
block
psql:postgis.sql:1579: ERROR: current transaction is
block
psql:postgis.sql:1589: ERROR: current transaction is
block
psql:postgis.sql:1595: ERROR: current transaction is
block
psql:postgis.sql:1601: ERROR: current transaction is
block
psql:postgis.sql:1607: ERROR: current transaction is
block
psql:postgis.sql:1613: ERROR: current transaction is
block
psql:postgis.sql:1619: ERROR: current transaction is
block
psql:postgis.sql:1625: ERROR: current transaction is
block
psql:postgis.sql:1631: ERROR: current transaction is
block
psql:postgis.sql:1641: ERROR: current transaction is
block
psql:postgis.sql:1647: ERROR: current transaction is
block
psql:postgis.sql:1653: ERROR: current transaction is
block
psql:postgis.sql:1659: ERROR: current transaction is
block
psql:postgis.sql:1664: ERROR: current transaction is
block
psql:postgis.sql:1674: ERROR: current transaction is
block
psql:postgis.sql:1679: ERROR: current transaction is
block
psql:postgis.sql:1684: ERROR: current transaction is
block
psql:postgis.sql:1689: ERROR: current transaction is
block
psql:postgis.sql:1695: ERROR: current transaction is
block
psql:postgis.sql:1700: ERROR: current transaction is
block
psql:postgis.sql:1705: ERROR: current transaction is
block
psql:postgis.sql:1711: ERROR: current transaction is
block
psql:postgis.sql:1717: ERROR: current transaction is
block
psql:postgis.sql:1723: ERROR: current transaction is
block
psql:postgis.sql:1728: ERROR: current transaction is
block
psql:postgis.sql:1735: ERROR: current transaction is
block
psql:postgis.sql:1741: ERROR: current transaction is
block
psql:postgis.sql:1746: ERROR: current transaction is
block
psql:postgis.sql:1751: ERROR: current transaction is
block
psql:postgis.sql:1756: ERROR: current transaction is
block
psql:postgis.sql:1761: ERROR: current transaction is
block
psql:postgis.sql:1766: ERROR: current transaction is
block
psql:postgis.sql:1771: ERROR: current transaction is
block
psql:postgis.sql:1776: ERROR: current transaction is
block
psql:postgis.sql:1781: ERROR: current transaction is
block
psql:postgis.sql:1786: ERROR: current transaction is
block
psql:postgis.sql:1791: ERROR: current transaction is
block
psql:postgis.sql:1801: ERROR: current transaction is
block
psql:postgis.sql:1806: ERROR: current transaction is
block
psql:postgis.sql:1821: ERROR: current transaction is
block
psql:postgis.sql:1826: ERROR: current transaction is
block
psql:postgis.sql:1831: ERROR: current transaction is
block
psql:postgis.sql:1840: ERROR: current transaction is
block
psql:postgis.sql:1849: ERROR: current transaction is
block
psql:postgis.sql:1858: ERROR: current transaction is
block
psql:postgis.sql:1867: ERROR: current transaction is
block
psql:postgis.sql:1876: ERROR: current transaction is
block
psql:postgis.sql:1881: ERROR: current transaction is
block
psql:postgis.sql:1886: ERROR: current transaction is
block
psql:postgis.sql:1910: ERROR: current transaction is
block
psql:postgis.sql:1914: ERROR: current transaction is
block
psql:postgis.sql:1925: ERROR: current transaction is
block
psql:postgis.sql:1938: ERROR: current transaction is
block
psql:postgis.sql:1939: ERROR: current transaction is
block
psql:postgis.sql:1940: ERROR: current transaction is
block
psql:postgis.sql:1941: ERROR: current transaction is
block
psql:postgis.sql:1942: ERROR: current transaction is
block
psql:postgis.sql:1943: ERROR: current transaction is
block
psql:postgis.sql:1944: ERROR: current transaction is
block
psql:postgis.sql:2103: ERROR: current transaction is
block
psql:postgis.sql:2120: ERROR: current transaction is
block
psql:postgis.sql:2137: ERROR: current transaction is
block
psql:postgis.sql:2214: ERROR: current transaction is
block
psql:postgis.sql:2235: ERROR: current transaction is
block
psql:postgis.sql:2256: ERROR: current transaction is
block
psql:postgis.sql:2309: ERROR: current transaction is
block
psql:postgis.sql:2321: ERROR: current transaction is
block
psql:postgis.sql:2334: ERROR: current transaction is
block
psql:postgis.sql:2389: ERROR: current transaction is
block
psql:postgis.sql:2445: ERROR: current transaction is
block
psql:postgis.sql:2459: ERROR: current transaction is
block
psql:postgis.sql:2467: ERROR: current transaction is
block
psql:postgis.sql:2483: ERROR: current transaction is
block
psql:postgis.sql:2492: ERROR: current transaction is
block
psql:postgis.sql:2500: ERROR: current transaction is
block
psql:postgis.sql:2509: ERROR: current transaction is
block
psql:postgis.sql:2514: ERROR: current transaction is
block
psql:postgis.sql:2519: ERROR: current transaction is
block
_________________________________________________________
Do You Yahoo!?
150万曲MP3疯狂搜,带您闯入音乐殿堂
http://music.yisou.com/
美女明星应有尽有,搜遍美图、艳图和酷图
http://image.yisou.com
1G就是1000兆,雅虎电邮自助扩容!
http://cn.rd.yahoo.com/mail_cn/tag/1g/*http://cn.mail.yahoo.com/event/mail_1g/
