[postgis-users] java and postgis: your suggestions and ideas
Seamus Thomas Carroll carrolls at cpsc.ucalgary.ca
Tue Feb 3 14:19:15 PST 2004
I have looked into using JUMP but from what I last read JUMP1.1 does not
support postgis.  Has this changed?  If there is a postgis driver for
jump1.1 that has not been officialy released where can I get it.
Regards to GISToolkit:
Would an accuracy problem cause some layers to appear correctly while
causing another layer to dissappear?  If this is so I will look into the
code and follow your advice.
Seamus
On Tue, 3 Feb 2004, Jody Garnett wrote:
> Seamus Thomas Carroll wrote:
> >For the past two weeks I have been working with the GISToolKitEditor
> >changing it to suite my needs.  I did some testing today where I add a few
> >layers from the database and zoom in.  As I zoom in closer a specific
> >layer begins to distort or disappear.  It is not a postgis issue because i
> It really just sounds like you are running into accuracy issues, The
> conversion from double coordinates maintained by Postgis to the Java
> Shape which use float are probably to blame.  Try and take manual
> control of the zoom process and make sure doubles are used for as long
> as possible.
> >2) I may be forced to change java libraries so can anyone recommend a
> >different java library that I can use as a stand alone tool?
> JUMP Exists, has a Postgis loader. It is GPL, runs as a stand alone tool.
> GeoTools2 exists has a Postgis data store and some renderers, it is not
> a stand alone tool. But is LGPL.
> >I have other suggestions and question but I have not recieved a response
> >to my first question on the GISToolkit Sourceforge website.
> Cheers,
> Jody, Refractions Research
> postgis-users mailing list
