[postgis-users] PostGIS install
Eric Wright
eric.linux at shaw.ca
Wed Feb 11 08:55:37 PST 2004
Thanks for the tip Paul that got me up and running again.
Eric
Paul Ramsey wrote:
> Far easier is to use the appropriate system tools:
> On Linux:
> - First make sure that /usr/local/bin appears in /etc/ld.so.con
> - Run /sbin/ldconfig
> - Profit
> You will find that all symlinks are automatically added and maintained.
> On Tuesday, February 10, 2004, at 01:54 AM, Darren Houston wrote:
>> Good evening accidentally turned into good morning for me :).
>> The problem is that PostGIS can't find the GEOS library
>> (libgeos.so.1). Did you
>> install GEOS? Did you install Proj4 support? You don't need to
>> install any of
>> these (although I would recommend them), but before you compile and
>> install
>> PostGIS you need to edit the makefile in the PostGIS source directory
>> and change
>> USE_PROJ= to 0 and USE_GEOS= to 0 (or conversely, keep them at their
>> default, 1,
>> install GEOS/Proj4 and modify GEOS_DIR and PROJ_DIR to point to your
>> installations). If you have installed GEOS and/or Proj4, make a
>> symbolic link to
>> the GEOS/Proj4 libraries in /usr/local/pgsql/lib/ using the command;
>> ln -s location_of_library name_of_library
>> On my system, for GEOS, I cd to /usr/local/pgsql/lib and type;
>> ln -s /usr/local/geos/lib/libgeos.so.1.0.0 libgeos.so
>> ln -s /usr/local/geos/lib/libgeos.so.1.0.0 libgeos.so.1
>> ln -s /usr/local/geos/lib/libgeos.so.1.0.0 libgeos.so.1.0.0
>> This will make symbolic links called libgeos.so, libgeos.so.1,
>> libgeos.so.1.0.0
>> that point to the actual GEOS library named libgeos.so.1.0.0. Do not
>> use hard
>> links. The -s specifies symbolic. Type man ln for help.
>> If you didn't install GEOS/Proj4, you could try installing Proj4 and
>> GEOS into
>> /usr/local, making the symbolic links and seeing what happens. This is
>> theoretical, I've never tried this. After that, you will have to
>> compile and
>> install PostGIS again.
>> Hope this helps.
>> Eric Wright <eric.linux at shaw.ca> said:
>>> Good evening,
>>> I am trying to install the postgis package and when I get to the step:
>>> | psql -d yourtestdatabase -f postgis.sql
>>> I get the following error:
>>> psql:postgis.sql:44: NOTICE: type "histogram2d" is not yet defined
>>> DETAIL: Creating a shell type definition.
>>> psql:postgis.sql:44: ERROR: could not load library
>>> "/usr/local/pgsql/lib/libpostgis.so.0.8":
>>> libgeos.so.1: cannot open shared object file: No such file or
>>> directory
>>> I am can browse to the directory where the ||/usr/local/pgsql/lib/
>>> directory and verify that the file (or a link to the file) does
>>> exist so
>>> I am at a loss as to why it is complaining.
>>> In case you have not guessed yet I am fairly new to the Linux thing so
>>> any help will be greatly appreciated.
>>> Thanks in advance
>>> Eric W
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Darren Houston
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
