[postgis-users] Re:geos install problem
James S reid
james.reid at ed.ac.uk
Thu Feb 19 07:13:45 PST 2004
apologies should have it:
uname -a SunOS dearg 5.8 Generic_108528-27 sun4u sparc SUNW,Sun-Fire
compiler gcc 2.95.3
gmake 3.8
cheers
james
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, February 19, 2004 3:07 PM
Subject: Re: [postgis-users] Re:geos install problem
> Platform, compiler, etc?
> On Thursday, February 19, 2004, at 01:41 AM, James S reid wrote:
> > hi! Im trying to build postgis 0.8.1 and geos1.0 (against postgres
> > 7.4.1)- I
> > can acehive this succesfully if i omit support for geos but if i set
> > the
> > flag to 2 and point to my geos install directory the make fails.
> > I havent seen anything on the list that looks like an answer - help!!!
> > below is a tail of the compilation errors and exit codes:
> > geos::GeometryFactory::createPolygon(geos::LinearRing *,
> > vector<geos::Geometry *, allocator<geos::Geometry *> > *) 0x1a14
> > postgis_geos_wrapper.o
> > geos::GEOSException type_info node 0x24 postgis_geos_wrapper.o
> > geos::GEOSException type_info node 0x2c postgis_geos_wrapper.o
> > geos::LineString::getCoordinatesRO(void) const0x5dd8
> > geos::LineString::getCoordinatesRO(void) const0x5ed0
> > geos::BasicCoordinateList::BasicCoordinateList(int)0x978
> > geos::BasicCoordinateList::BasicCoordinateList(int)0x1680
> > geos::BasicCoordinateList::BasicCoordinateList(int)0x181c
> > geos::IntersectionMatrix::toString(void)0x2e58
> > geos::GeometryFactory::getPrecisionModel(void) const0x154
> > geos::GEOSException type_info function0x18
> > geos::GeometryFactory::createLineString(geos::CoordinateList const
> > *)0xa88
> > geos::GeometryFactory::createPoint(geos::Coordinate const &)0x708
> > geos::GeometryFactory::GeometryFactory(geos::PrecisionModel const *,
> > int)0x48 postgis_geos_wrapper.o
> > geos::PrecisionModel::PrecisionModel(void)0x34
> > geos::GeometryFactory::createMultiLineString(vector<geos::Geometry *,
> > allocator<geos::Geometry *> > *) 0x1088
> > geos::GeometryFactory::createMultiPolygon(vector<geos::Geometry *,
> > allocator<geos::Geometry *> > *) 0xd84
> > geos::GeometryFactory::toGeometry(geos::Envelope *,
> > geos::PrecisionModel *,
> > int)0x164 postgis_geos_wrapper.o
> > geos::GeometryFactory::createMultiPoint(vector<geos::Geometry *,
> > allocator<geos::Geometry *> > *) 0x138c
> > geos::Envelope::Envelope(double, double, double, double)0x120
> > geos::GeometryFactory::buildGeometry(vector<geos::Geometry *,
> > allocator<geos::Geometry *> > *) 0x418
> > geos::GeometryFactory::createLinearRing(geos::CoordinateList *)
> > 0x1798
> > 0x1944
> > ld: fatal: relocations remain against allocatable but non-writable
> > sections
> > collect2: ld returned 1 exit status
> > gmake: *** [libpostgis.so.0.8] Error 1
> > thoughts welcome : )
> > James S Reid
> > GeoData Services
> > EDINA
> > University of Edinburgh
> > Main Library
> > George Square
> > EH8 9LJ
> > tel: +44 (0) 131 651 1383
> > fax: +44 (0) 131 650 3308
> > email: james.reid at ed.ac.uk
> > "Programming today is a race between software engineers striving
> > to build bigger and better idiot-proof programs, and the Universe
> > trying to produce bigger and better idiots.
> > So far, the Universe is winning."
> > Rich Cook
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
