[postgis-users] Re:geos install problem
David Valentine
valentine at library.ucsb.edu
Thu Feb 19 08:22:35 PST 2004
Funny, same problem with gcc 3.2/3.3
set a CFLAGS env variable
CFLAGS=-fPIC
James S reid wrote:
> apologies should have it:
> uname -a SunOS dearg 5.8 Generic_108528-27 sun4u sparc SUNW,Sun-Fire
> compiler gcc 2.95.3
> gmake 3.8
> cheers
> james
> ----- Original Message -----
> From: "Paul Ramsey" <pramsey at refractions.net>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, February 19, 2004 3:07 PM
> Subject: Re: [postgis-users] Re:geos install problem
>>Platform, compiler, etc?
>>On Thursday, February 19, 2004, at 01:41 AM, James S reid wrote:
>>>hi! Im trying to build postgis 0.8.1 and geos1.0 (against postgres
>>>7.4.1)- I
>>>can acehive this succesfully if i omit support for geos but if i set
>>>the
>>>flag to 2 and point to my geos install directory the make fails.
>>>I havent seen anything on the list that looks like an answer - help!!!
>>>below is a tail of the compilation errors and exit codes:
>>>geos::GeometryFactory::createPolygon(geos::LinearRing *,
>>>vector<geos::Geometry *, allocator<geos::Geometry *> > *) 0x1a14
>>>postgis_geos_wrapper.o
>>>geos::GEOSException type_info node 0x24 postgis_geos_wrapper.o
>>>geos::GEOSException type_info node 0x2c postgis_geos_wrapper.o
>>>geos::LineString::getCoordinatesRO(void) const0x5dd8
>>>geos::LineString::getCoordinatesRO(void) const0x5ed0
>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x978
>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x1680
>>>geos::BasicCoordinateList::BasicCoordinateList(int)0x181c
>>>geos::IntersectionMatrix::toString(void)0x2e58
>>>geos::GeometryFactory::getPrecisionModel(void) const0x154
>>>geos::GEOSException type_info function0x18
>>>geos::GeometryFactory::createLineString(geos::CoordinateList const
>>>*)0xa88
>>>geos::GeometryFactory::createPoint(geos::Coordinate const &)0x708
>>>geos::GeometryFactory::GeometryFactory(geos::PrecisionModel const *,
>>>int)0x48 postgis_geos_wrapper.o
>>>geos::PrecisionModel::PrecisionModel(void)0x34
>>>geos::GeometryFactory::createMultiLineString(vector<geos::Geometry *,
>>>allocator<geos::Geometry *> > *) 0x1088
>>>geos::GeometryFactory::createMultiPolygon(vector<geos::Geometry *,
>>>allocator<geos::Geometry *> > *) 0xd84
>>>geos::GeometryFactory::toGeometry(geos::Envelope *,
>>>geos::PrecisionModel *,
>>>int)0x164 postgis_geos_wrapper.o
>>>geos::GeometryFactory::createMultiPoint(vector<geos::Geometry *,
>>>allocator<geos::Geometry *> > *) 0x138c
>>>geos::Envelope::Envelope(double, double, double, double)0x120
>>>geos::GeometryFactory::buildGeometry(vector<geos::Geometry *,
>>>allocator<geos::Geometry *> > *) 0x418
>>>geos::GeometryFactory::createLinearRing(geos::CoordinateList *)
>>>0x1798
>>>0x1944
>>>ld: fatal: relocations remain against allocatable but non-writable
>>>sections
>>>collect2: ld returned 1 exit status
>>>gmake: *** [libpostgis.so.0.8] Error 1
>>>thoughts welcome : )
>>>James S Reid
>>>GeoData Services
>>>EDINA
>>>University of Edinburgh
>>>Main Library
>>>George Square
>>>EH8 9LJ
>>>tel: +44 (0) 131 651 1383
>>>fax: +44 (0) 131 650 3308
>>>email: james.reid at ed.ac.uk
>>>"Programming today is a race between software engineers striving
>>>to build bigger and better idiot-proof programs, and the Universe
>>>trying to produce bigger and better idiots.
>>>So far, the Universe is winning."
>>> Rich Cook
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Paul Ramsey
>> Refractions Research
>> Email: pramsey at refractions.net
>> Phone: (250) 885-0632
