[postgis-users] Re:geos install problem
James S reid
james.reid at ed.ac.uk
Fri Feb 20 00:31:19 PST 2004
hi - thanks for the suggestion but I still get an abortive make (and yes I
did make clean first!!)
anyone any additional thoughts? I seem to recall a warning about Bison
versions somehere?
cheers
james
----- Original Message -----
From: "David Valentine" <valentine at library.ucsb.edu>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, February 19, 2004 4:22 PM
Subject: Re: [postgis-users] Re:geos install problem
> Funny, same problem with gcc 3.2/3.3
> set a CFLAGS env variable
> CFLAGS=-fPIC
> James S reid wrote:
> > apologies should have it:
> > uname -a SunOS dearg 5.8 Generic_108528-27 sun4u sparc SUNW,Sun-Fire
> > compiler gcc 2.95.3
> > gmake 3.8
> > cheers
> > james
> > From: "Paul Ramsey" <pramsey at refractions.net>
> > Sent: Thursday, February 19, 2004 3:07 PM
> >>Platform, compiler, etc?
> >>On Thursday, February 19, 2004, at 01:41 AM, James S reid wrote:
> >>>hi! Im trying to build postgis 0.8.1 and geos1.0 (against postgres
> >>>7.4.1)- I
> >>>can acehive this succesfully if i omit support for geos but if i set
> >>>the
> >>>flag to 2 and point to my geos install directory the make fails.
> >>>I havent seen anything on the list that looks like an answer - help!!!
> >>>below is a tail of the compilation errors and exit codes:
> >>>geos::GeometryFactory::createPolygon(geos::LinearRing *,
> >>>vector<geos::Geometry *, allocator<geos::Geometry *> > *) 0x1a14
> >>>postgis_geos_wrapper.o
> >>>geos::GEOSException type_info node 0x24 postgis_geos_wrapper.o
> >>>geos::GEOSException type_info node 0x2c postgis_geos_wrapper.o
> >>>geos::LineString::getCoordinatesRO(void) const0x5dd8
> >>>geos::LineString::getCoordinatesRO(void) const0x5ed0
> >>>geos::BasicCoordinateList::BasicCoordinateList(int)0x978
> >>>geos::BasicCoordinateList::BasicCoordinateList(int)0x1680
> >>>geos::BasicCoordinateList::BasicCoordinateList(int)0x181c
> >>>geos::IntersectionMatrix::toString(void)0x2e58
> >>>geos::GeometryFactory::getPrecisionModel(void) const0x154
> >>>geos::GEOSException type_info function0x18
> >>>geos::GeometryFactory::createLineString(geos::CoordinateList const
> >>>*)0xa88
> >>>geos::GeometryFactory::createPoint(geos::Coordinate const &)0x708
> >>>geos::GeometryFactory::GeometryFactory(geos::PrecisionModel const *,
> >>>int)0x48 postgis_geos_wrapper.o
> >>>geos::PrecisionModel::PrecisionModel(void)0x34
> >>>geos::GeometryFactory::createMultiLineString(vector<geos::Geometry *,
> >>>allocator<geos::Geometry *> > *) 0x1088
> >>>geos::GeometryFactory::createMultiPolygon(vector<geos::Geometry *,
> >>>allocator<geos::Geometry *> > *) 0xd84
> >>>geos::GeometryFactory::toGeometry(geos::Envelope *,
> >>>geos::PrecisionModel *,
> >>>int)0x164 postgis_geos_wrapper.o
> >>>geos::GeometryFactory::createMultiPoint(vector<geos::Geometry *,
> >>>allocator<geos::Geometry *> > *) 0x138c
> >>>geos::Envelope::Envelope(double, double, double, double)0x120
> >>>geos::GeometryFactory::buildGeometry(vector<geos::Geometry *,
> >>>allocator<geos::Geometry *> > *) 0x418
> >>>geos::GeometryFactory::createLinearRing(geos::CoordinateList *)
> >>>0x1798
> >>>0x1944
> >>>ld: fatal: relocations remain against allocatable but non-writable
> >>>sections
> >>>collect2: ld returned 1 exit status
> >>>gmake: *** [libpostgis.so.0.8] Error 1
> >>>thoughts welcome : )
> >>>James S Reid
> >>>GeoData Services
> >>>EDINA
> >>>University of Edinburgh
> >>>Main Library
> >>>George Square
> >>>EH8 9LJ
> >>>tel: +44 (0) 131 651 1383
> >>>fax: +44 (0) 131 650 3308
> >>>email: james.reid at ed.ac.uk
> >>>"Programming today is a race between software engineers striving
> >>>to build bigger and better idiot-proof programs, and the Universe
> >>>trying to produce bigger and better idiots.
> >>>So far, the Universe is winning."
> >>> Rich Cook
> >>>_______________________________________________
> >>>postgis-users mailing list
> >>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> Paul Ramsey
> >> Refractions Research
> >> Email: pramsey at refractions.net
> >> Phone: (250) 885-0632
