[postgis-users] Re:geos install problem
Tyler Mitchell TMitchell at lignum.com
Fri Feb 20 08:31:03 PST 2004
James,
How did you grab geos?  From CVS (when?) or the 1.0.0 tar file?  It's a
long shot, but you might want to try grabbing a different set, or at least
removing and re downloading the code.  My comments are lame but I didn't
want to leave a Scot in a bind :)
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 02/20/2004 12:31:19
AM:
> hi - thanks for the suggestion but I still get an abortive make (and yes
I
> did make clean first!!)
> anyone any additional thoughts? I seem to recall a warning about Bison
> versions somehere?
> cheers
> james
> ----- Original Message -----
> From: "David Valentine" <valentine at library.ucsb.edu>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, February 19, 2004 4:22 PM
> Subject: Re: [postgis-users] Re:geos install problem
> > Funny, same problem with gcc 3.2/3.3
> > set a CFLAGS env variable
> > CFLAGS=-fPIC
> > James S reid wrote:
> > > apologies should have it:
> > > uname -a SunOS dearg 5.8 Generic_108528-27 sun4u sparc SUNW,Sun-Fire
> > > compiler gcc 2.95.3
> > > gmake 3.8
> > > cheers
> > > james
> > > From: "Paul Ramsey" <pramsey at refractions.net>
> > > Sent: Thursday, February 19, 2004 3:07 PM
> > >>Platform, compiler, etc?
> > >>On Thursday, February 19, 2004, at 01:41 AM, James S reid wrote:
> > >>>hi! Im trying to build postgis 0.8.1 and geos1.0 (against postgres
> > >>>7.4.1)- I
> > >>>can acehive this succesfully if i omit support for geos but if i
set
> > >>>the
> > >>>flag to 2 and point to my geos install directory the make fails.
> > >>>I havent seen anything on the list that looks like an answer -
help!!!
> > >>>below is a tail of the compilation errors and exit codes:
> > >>>geos::GeometryFactory::createPolygon(geos::LinearRing *,
> > >>>vector<geos::Geometry *, allocator<geos::Geometry *> > *) 0x1a14
> > >>>postgis_geos_wrapper.o
> > >>>geos::GEOSException type_info node  0x24 postgis_geos_wrapper.o
> > >>>geos::GEOSException type_info node  0x2c postgis_geos_wrapper.o
> > >>>geos::LineString::getCoordinatesRO(void) const0x5dd8
> > >>>geos::LineString::getCoordinatesRO(void) const0x5ed0
> > >>>geos::BasicCoordinateList::BasicCoordinateList(int)0x978
> > >>>geos::BasicCoordinateList::BasicCoordinateList(int)0x1680
> > >>>geos::BasicCoordinateList::BasicCoordinateList(int)0x181c
> > >>>geos::IntersectionMatrix::toString(void)0x2e58
> > >>>geos::GeometryFactory::getPrecisionModel(void) const0x154
> > >>>geos::GEOSException type_info function0x18
> > >>>geos::GeometryFactory::createLineString(geos::CoordinateList const
> > >>>*)0xa88
> > >>>geos::GeometryFactory::createPoint(geos::Coordinate const &)0x708
> > >>>geos::GeometryFactory::GeometryFactory(geos::PrecisionModel const
> > >>>int)0x48           postgis_geos_wrapper.o
> > >>>geos::PrecisionModel::PrecisionModel(void)0x34
> > >>>geos::GeometryFactory::createMultiLineString(vector<geos::Geometry
> > >>>allocator<geos::Geometry *> > *)     0x1088
> > >>>geos::GeometryFactory::createMultiPolygon(vector<geos::Geometry *,
> > >>>allocator<geos::Geometry *> > *)     0xd84
> > >>>geos::GeometryFactory::toGeometry(geos::Envelope *,
> > >>>geos::PrecisionModel *,
> > >>>int)0x164           postgis_geos_wrapper.o
> > >>>geos::GeometryFactory::createMultiPoint(vector<geos::Geometry *,
> > >>>allocator<geos::Geometry *> > *)     0x138c
> > >>>geos::Envelope::Envelope(double, double, double, double)0x120
> > >>>geos::GeometryFactory::buildGeometry(vector<geos::Geometry *,
> > >>>allocator<geos::Geometry *> > *)     0x418
> > >>>geos::GeometryFactory::createLinearRing(geos::CoordinateList *)
> > >>>0x1798
> > >>>0x1944
> > >>>ld: fatal: relocations remain against allocatable but non-writable
> > >>>sections
> > >>>collect2: ld returned 1 exit status
> > >>>gmake: *** [libpostgis.so.0.8] Error 1
> > >>>thoughts welcome : )
> > >>>James S Reid
> > >>>GeoData Services
> > >>>EDINA
> > >>>University of Edinburgh
> > >>>Main Library
> > >>>George Square
> > >>>EH8 9LJ
> > >>>tel:     +44 (0) 131 651 1383
> > >>>fax:    +44 (0) 131 650 3308
> > >>>email: james.reid at ed.ac.uk
> > >>>"Programming today is a race between software engineers striving
> > >>>to build bigger and better idiot-proof programs, and the Universe
> > >>>trying to produce bigger and better idiots.
> > >>>So far, the Universe is winning."
> > >>>    Rich Cook
> > >>>_______________________________________________
> > >>>postgis-users mailing list
> > >>>http://postgis.refractions.net/mailman/listinfo/postgis-users
> > >>      Paul Ramsey
> > >>      Refractions Research
> > >>      Email: pramsey at refractions.net
> > >>      Phone: (250) 885-0632
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040220/a80818e4/attachment.html>
