[postgis-users] PostGIS Capabilities
Jong S. Lee
jonglee1 at uiuc.edu
Thu Feb 19 13:50:19 PST 2004
Paul Ramsey wrote:
> On Thursday, February 19, 2004, at 02:03 AM, Chris Haste wrote:
>> Given an irregular closed polygon can we perform SQL statements along
>> the lines of "give me all the points that reside within the polygon?
> SELECT POINTS FROM MYTABLE WHERE
> CONTAINS(GEOMETRYFROMTEXT('POLYGON(..)', SRID), POINTS)
>> Given the same polygon can we obtain all the lines that intersect
>> the polygon?
> SELECT LINES FROM MYTABLE WHERE NOT
> DISJOINT(GEOMETRYFROMTEXT('POLYGON(..)', SRID), LINES)
>> For the above are the coordinates of the intersection points
>> calculated and obtainable?
> SELECT INTERSECTION(LINES, GEOMETRYFROMTEXT('POLYGON(..)',SRID)) FROM
> MYTABLE WHERE NOT DISJOINT(GEOMETRYFROMTEXT('POLYGON(..)', SRID), LINES)
>> Can we obtain all the points within a certain radius of a specified
>> points?
> SELECT * FROM MYTABLE WHERE
> DISTANCE(POINTS,GEOMETRYFROMTEXT('POINT(..)',SRID)) > RADIUS
>> Can we obtain all the lines that reside entirely (without
>> intersecting the boundary) within a circle or an ellipse?
> If you construct the circle or ellipse into a polygon that
> approximates the shape, you can use the WITHIN() or CONTAINS()
> functions for a strict test of containment.
>> Is it possible to specify the segments of a polygon as being either a
>> straight line, a rhumb line or a great circle? This is necessary to
>> avoid problems to do with the curvature of the earth.
> No. You can calculate length_spheroid() directly on the spheroid, but
> that is the only geodetic function we have so far.
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
Wow... Amazing PostGIS!!
Question: How to select points on the line? For example, how to
select the bridges on the highway?
Jong.
Jong Sung Lee, Graduate Research Assistant
Department of Urban and Regional Planning
University of Illinois at Urbana-Champaign
111 Temple Hoyne Buell Hall
611 East Loredo Taft Dr.
Champaign, IL 61820
Tel:(217)244-6564
E-mail:jonglee1 at uiuc.edu
