[postgis-users] PostGIS Capabilities
Tyler Mitchell TMitchell at lignum.com
Thu Feb 19 14:23:13 PST 2004
Hi Jong,
> Wow... Amazing PostGIS!!
That's the spirit!
> Question:     How to select points on the line?  For example, how to
> select the bridges on the highway?
Good practical question - I get excited thinking about just how easy this
is to do (with no licensing fees involved!).
I think it will depend on how you define "on the line".  Do the bridge
share the same point as a node in your line?  Or (as I assume is the case)
are your points within a certain distance from a line (i.e. < 10 metres)?
If the latter, then something like this should do the trick:
SELECT bridges.name
FROM bridges, highways
WHERE DISTANCE(bridges.geometrycolumn, highways.geometrycolumn) < 10;
There are ways to optimize this query, I just gave you the most basic.
Hope that helps you out.
Tyler
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040219/47c6504f/attachment.html>
