[postgis-users] PostGIS Capabilities
Tyler Mitchell TMitchell at lignum.com
Fri Feb 20 08:36:54 PST 2004
> I agree with you opinion. However, the bridge data (point shape file) is
> created based on the highway data.  The highway data has LRS (linear
> referencing system) to locate the point (or event) on the highway.  The
> bridge data is created via LRS.  Therefore, it should be exactly on the
> highway.
I hadn't considered this possibility in my tirade last night. Interesting.
> the precision of the coordinates might be changed when I converted
> shapefile to PostGIS db table.
It'd be interesting to compare the precision of the coordinates.
> Actually, ArcGIS give you the option field about buffer distance.  I
> used 0 value for the buffer distance.  And, in ArcGIS, even if I zoom in
> as far as possible, the points (bridge) are on the line.
For academia sake, I wonder what you'd see if you export from postgis back
into shape and compare the precise locations in ArcMap.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040220/7bafa0bf/attachment.html>
